Protomotive 3.8l built
Old Mar 3, 2014 | 09:53 PM
orbelo's Avatar
orbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud of
Nice build man, enjoy it.
Old Mar 9, 2014 | 12:30 PM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
Today was a rainy day,nothing to do so i decided to go to my shop to remove the engine,it tooks me 4 hours to do it,first i removed the bumper,ICs,Exhaust and turbos,cooling hoses,etc... then removed the engine/transmission.
ID:	343851   Click image for larger version
Old Mar 9, 2014 | 01:12 PM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
You redid the under drive pulley and wheel? Why did you upgrade it? What does it do? I lack knowledge in this area. Thanks for any help!!
Old Mar 9, 2014 | 01:32 PM
johnspeed's Avatar
[QUOTE=Wealth Manager;4064430]You redid the under drive pulley and wheel? Why did you upgrade it? What does it do? I lack knowledge in this area. Thanks for any help!![/QUOTE
Lighter and smaller easier to turn requiring less HP to turn.
Old Mar 9, 2014 | 01:36 PM
[QUOTE=johnspeed;4064437]
So the difference is minimal? Does it make it safer when raising the Rev limiter?
Old Mar 9, 2014 | 02:10 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
[QUOTE=Wealth Manager;4064438]
the original idea was a better mounting to the crank cause they were spinning off and coming loose, then they improved the rest of design made them smaller, and drive the accessories slower also.
Old Mar 9, 2014 | 02:50 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Originally Posted by unvmy996
I see 3.6 motors making just as much power if not more .... So other then the cool factor is there any other reason to do a 3.8?
The fact the 3,8 kit I bolt was fitted with ductile liners was more important than the gain to 3,746cc.
Mine is from FVD/Mahle, I see Todd uses another brand on Ali's and Dave's pictures but I believe their liners are ductile as well.
The 5% displacement gain is not all, the little lower CR allows a little more boost before knocking, and more power.
Old Mar 9, 2014 | 03:08 PM
Isn't there also the downfall of going 3.8l since the sleeves will be thinner and won't last as long and can be prone to cracking??
Old Mar 9, 2014 | 07:57 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
Please bring this to Byblos this summer!
Old Mar 9, 2014 | 08:27 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
[QUOTE=OS Inspector;4064456]
exactly!
Old Mar 9, 2014 | 08:29 PM
joetwint's Avatar
No that is not a problem at 3.8.It can be a concern though with the next size bigger liner.
Old Mar 11, 2014 | 12:39 PM
VAGscum's Avatar
In most cases,,a larger engine will have better throttle response and more power off boost And IF IT CAN get feed enough it will make more power on the same boost levels..
But my concern with aftermarket pistons and liners is longevity. Stock pistons and liners are quite reliable and durable. They also do not experience as much oil blow by due to hot/cold expansion contraction issues like many CP pistons which are race intended. In my experience their is no sense upgrading engine internals to race spec parts when you want to daily drive unless you intend on more frequent rebuild intervals. So that being said, wouldn't you get the same gains with some head work and maybe cams? Maybe throttle body upgrade and larger y-pipe? And those mods are not going to induce more problems if properly done. Just my $.02
That being said, to the OP. I think you will be extremely happy regardless. Enjoy!
Old Mar 11, 2014 | 01:04 PM
johnspeed's Avatar
Yes it all boils down to how much does some want to give up or Pay for that little extra power. . LOL
How many have pushed their projects from a reliable Street car to a weekend warrior only?
Old Mar 11, 2014 | 01:39 PM
VAGscum's Avatar
Yes it all boils down to how much does some want to give up or Pay for that little extra power. . LOL How many have pushed their projects from a reliable Street car to a weekend warrior only?
I completely agree.
Old Mar 11, 2014 | 02:13 PM
Vagscum have you seen someone wear out a forged 996tt motor? Forged piston ductile iron liners I mean.
