PSI 800 Article
Originally posted by Neil
Crash....When they tested the car they had a big problem with traction. The car was originally 850hp but the car was un drivable so it was backed off to just over 800hp.
Interesting. My GT2 GT700/750 courtesy of Imagine Auto and Evolution Motorsports made 637RWHP @ 5500RPM & 645RWTQ @ 5000RPM on 100 unleaded @ 1.5 BAR on a very conservative Mustang Dyno. Using PSI's drivetrain loss factor, this equates to 758FWHP and 767FWTQ. That means that I am making only 49 less FWHP (807 for PSI) at 800 less RPM, but I am making 95 more FWTQ (672 for PSI) at 220 less RPM.
I remember a lot of discussion about making power under the curve...looks like EVOMS, Imagine Auto, and GIAC have figured that one out. Sure, I run a little higher boost, but who cares? If the programming and fuel needs are sufficient, a little smaller turbo and a little more boost can do wonderful things.
Neil, what are they using for fuel in that car?
That is a badass ride by the way. How much for the added girth?
Cleve
Cleve you also have one bad *** car.
The dyno's used in Europe are very different from the ones used in the USA and are very conservative.
My reasoning for this comment is that our 650hp Motor only made 495ps @ the wheels yet was able to achieve 0-60 in 3.1 sec & 1/4 mile in 11.1 sec.
Cleve hope to see you at the next DE at Road Atlanta and see your beast in person.
Neil
Neil
Neil
Neil
Should be at the October 29, 30 PCA DE. See you there.
Cleve
Neil
Neil
Originally posted by Itzkirb
arguing/debating is 1/2 the fun
Let's Get It On!
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
