Sway Bars
Old Sep 16, 2005 | 11:47 AM
  #31
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
Originally posted by sharkster
I like the new H&Rs.. actually thicker diameter than the GT3 or Eibach kits... I prefer it that way. All about the girth!
lol your always compensatiing heheheh
got any new pics of the black mamba sharky?
Old Sep 16, 2005 | 02:39 PM
  #32
monsoonmadness's Avatar
monsoonmadness is infamous around these parts
Working on the pics as we speak.. Just put on a corbon wing that I bought on Ebay. Its a little wider than the stock one(Upper) I do alot of agressive driving and want a little more stiffness in the corners.
So what do you think I should do? My budget is 2 thousand and I want results!!
Old Sep 16, 2005 | 03:01 PM
  #33
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Originally posted by monsoonmadness
I do alot of agressive driving and want a little more stiffness in the corners. So what do you think I should do? My budget is 2 thousand and I want results!!
Good sway bars are considerably less than $2k . . . good coilovers are considerably more.
Craig
Old Sep 17, 2005 | 09:59 AM
  #34
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
Bars
I just wrote a long disertation on my experience and somehow it was dumped. I'll try to para-phrase. Porsche GT3 & GT2 sway bars are great (hollow/lighter/stiffer/not that expensive) but do not fit as a set for the standard turbo due to 4 wheel drive - had a GT2 and turbo on the racks at the same time so I got the visual. I have tried many suspension products on the track with my 01 996 and 03 tt both cars very far from stock. Bottom line is sway bars are biggest bang for your buck. I've got H&Rs and PSS9 and it is great at Sebring and fine on the road. The H&Rs were fine w/ stock suspension at the track - I just went all the way. go w/ the sway bars - they will fit your budget and you can add the suspension later. PSS9 only will be disappointing w/o better sway bars if you hit the track. Hope this helps ... spent some serious bucks learning this first hand at sebring.
Old Sep 17, 2005 | 10:35 AM
  #35
Zippy's Avatar
Re: Bars
What make the H&R front bar work better on the AWD 996TT? Are the drop links different? Are the bars themselves different?
Mike
Old Sep 17, 2005 | 11:14 AM
  #36
Sway bar
Difference is the bending to accomodate the 2 vs 4 wheel drive. I would not recommend using one brand on front and another in the rear. Specifically I would not go with Porsche GT2 hollow bar and then H&R solid one. Get the H&R set - they are also adjustable.
Old Sep 17, 2005 | 11:20 AM
  #37
Swaybar
For some reason I'm having a posting problem, - anyway the Porsche GT2 bars are the best but the front of a GT2 is different than a standard turbo - the swaybar bends need to be different due to 2 vs 4 wheel drive. A few companies have tried to make some drop links to accomodate this difference but they will be the weak/fatige point in your susupension and they are expensive. I would still recommend the H&R Standard turbo bars for our application - even though they are solid and weigh more ... they work great on the road and at Sebring and again are adjustable.
Old Sep 17, 2005 | 05:01 PM
  #38
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
What you should do is look at the sway bars as a fine tuning instrument for a properly set up suspension , And NOT a Ace bandage for a poorly set up car.
Just my .02 cents.
Old Sep 17, 2005 | 05:33 PM
  #39
oak's Avatar
oak
I've had the hollow GT2/3 sways and have had no problems with TRG DL's. You need to unload the suspension and adjust the Dl's accordingly to eliminate the clearance issue. No problems what so ever.
Old Sep 19, 2005 | 09:35 AM
  #40
Sway bars
Earlier this year I got a quote on those DLs from TRG and they were more than a set of sway bars from H&R - and then you still needed to buy the Porsche sway bars. Has TRG lowered their price? I think this project and conversation started with a budget of $2k.
Old Sep 19, 2005 | 02:05 PM
  #41
Craig's Avatar
Re: Sway bars
I have had several different sets of drop links . . . the TRG DLs are clearly superior.
Craig
Old Sep 19, 2005 | 07:52 PM
  #42
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Just my .02 cents.
Ditto that.....well said.
