CM st3 issue
Old Mar 31, 2014 | 08:45 PM
fairbird's Avatar
fairbird has a spectacular aura aboutfairbird has a spectacular aura about
Question CM st3 issue
Hi all , My 911 just makes me "happy" with problem after problem , transmission ,window switch , key , tune by 911tuning (that actually makes me happy) but here is the news , today first time ever I saw after full boost hits at 4k rpm or so the rpw go up , the car not going any faster , clutch slip , I tried to step on it on 2nd gear feels ok , so I tried to make it slip different ways it might did it again but definitely not like a first time , so after talking to previous owner and finding the post of the owner before we find out that the clutch 10k miles old , 5k miles the car wasn't making power to destroy the clutch . and that why I'm posting this post , what would you do ? yes the clutches go bad , could be an engagement issue ? like fork ? pin , something in between it's impossible , but just in case . or just replace it and forget about it ? even if that will cost me . I'm tired to spend the money on it , to much since I have it , and I really start enjoy it after retune by Markski . I haven't decided yet if it worse it . Thanks for inputs guys . sorry for my english .
Old Mar 31, 2014 | 10:06 PM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
Have a shop look at it......and if the clutch is gone then replace it with something other then a CM.
I have the CM stage 3 and hate it.....
Old Mar 31, 2014 | 10:14 PM
fairbird's Avatar
I inspect it 1000 miles ago while I rebuild my transmition , looked ok with ton of life . How much shop will charge for replacing the clutch ?
Old Mar 31, 2014 | 10:20 PM
They need to drop the transmission, so maybe a $1000+. Matters on the shop obviously.
Old Mar 31, 2014 | 10:26 PM
fairbird's Avatar
Sounds like $4 the all story
Old Apr 1, 2014 | 12:14 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
So do you have a new clutch installed? or the factory clutch?
Old Apr 1, 2014 | 06:29 AM
fairbird's Avatar
I have cm st3 , according to car history 10–12 k miles old , half of that milage the car was weak
Old Apr 1, 2014 | 06:42 AM
996tt550hp's Avatar
I have the sameone when they installed it did they change the flywheel to a new one?
Old Apr 1, 2014 | 06:45 AM
fairbird's Avatar
yes , they did that the link to add
https://www.6speedonline.com/forums/...-warranty.html
Old Apr 1, 2014 | 06:47 AM
996tt550hp's Avatar
How many miles on the clutch?
Old Apr 1, 2014 | 06:48 AM
fairbird's Avatar
10–12000 , the car has 48000 right now.
Old Apr 1, 2014 | 10:18 AM
VAGscum's Avatar
I would check the slave and the clutch fork to see if they are binding and not releasing all the way. Because throwing another clutch in there with other problems will repeat the results. It is usually obvious when your clutch is toast. I bet you have other issues.
Old Apr 1, 2014 | 10:26 AM
fairbird's Avatar
do you think it's possible ? what can go wrong there ?
Old Apr 1, 2014 | 10:39 AM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
So i looked at the original ad and there was no indication of a new fly wheel with the CM ST3 clutch. If you are on the original fly wheel that could be the problem. Around here most people that go to ST3 clutch ended up with LWFW and complain about the noise. I'd go back to see if flywheel was ever changed and go from there.
Old Apr 1, 2014 | 10:46 AM
fairbird's Avatar
brand new FW was installed , I asked the owner . low rpm no boost the car drives fine , whitch is tells me it's eather one of the disks , am I'm wrong?
