CM st3 issue
Old Apr 1, 2014 | 11:07 AM
fairbird's Avatar
fairbird has a spectacular aura aboutfairbird has a spectacular aura about
Omaha dealer , just a labor 3100 lol , it's not going to happen. and we don't have any other shops here
Old Apr 1, 2014 | 11:11 AM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
Here what came up on a quick google search:
http://forums.rennlist.com/rennforum...-omaha-ne.html
Old Apr 1, 2014 | 11:13 AM
fairbird's Avatar
how could I forget about them , I know them , thanks a lot !
Old Apr 1, 2014 | 11:34 AM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
brand new FW was installed , I asked the owner . low rpm no boost the car drives fine , whitch is tells me it's eather one of the disks , am I'm wrong?
I think so, either way it would require tranny drop to access clucht and FW. 10-12K on a clutch with a modded engine and hard start stop can wear clucht prematurely too. Sounds like you are in need.... GL
Old Apr 1, 2014 | 11:40 AM
No problem, you're welcome.
Old Apr 1, 2014 | 11:49 AM
fairbird's Avatar
Thanks a lot , they give awesome price !
Old Apr 1, 2014 | 11:51 AM
Yup, any indy shop will beat the "Stealership" pricing for work.
Old Apr 1, 2014 | 12:27 PM
VAGscum's Avatar
When the transmission gets pulled you have to remove the clutch fork. It is a bit of a pain to go back together and if done improperly or if the bushing for the fork is shot than it will bind. The slave and master can fail in many ways. One way would be that it doesn't fully release pressure from the clutch fork. This causes partial clutch engagement which will slip under torque. The other thing that can cause issues is a RMS leak. The oil gets on the flywheel and clutch and those parts don't like to be lubed. Check the bell housing for signs of oil.
Old Apr 1, 2014 | 01:06 PM
fairbird's Avatar
that's helpfuul , thanks , I should take it a part first , fork might be the issue
Old Apr 1, 2014 | 01:41 PM
no way that clutch would slip at 1.2 bar on k16 billets...
not sure if they were forthcoming about it...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 1, 2014 | 01:58 PM
'02996ttx50's Avatar
When the transmission gets pulled you have to remove the clutch fork. It is a bit of a pain to go back together and if done improperly or if the bushing for the fork is shot than it will bind. The slave and master can fail in many ways. .
it can take a good 2,.. or even 3! attempts to line up the shift fork upon re-assembly. don't i know
Old Apr 1, 2014 | 02:06 PM
fairbird's Avatar
After I put it together I put 3000 miles already
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
georgemaser
Oct 17, 2015 05:59 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
oo7
Sep 10, 2015 08:08 AM
