Suspension Settings
Old Sep 12, 2005 | 10:28 PM
Zippy's Avatar
Suspension Settings
I had been using 4/15 on the fronts and 11/15 on the rears. This didn’t seem to work too well. Unfortunately I only had 1 track day with this setting. Around town, I seemed to be getting a lot of anti-lock when cornering at speeds where it seemed inappropriate. Not sure if related to the soft front settings. Tonight I firmed the front up to 8/15 and left the rears at 11/15. The car felt a lot more balanced and generally tighter. Turn in seemed to be crisper. Again, not sure if imagined or reality. FYI, I’m using medium (8kg/12kg) springs and GT3 sway bars set at 2/5 on the front and 4/5 in the rear. What settings are you using on your adjustable coil-overs that seem to your well?
Mike
Old Sep 12, 2005 | 10:35 PM
Ruiner's Avatar
Good question. I need to play with my JICs some more. I'll do that and get back to you.
Old Sep 13, 2005 | 03:01 PM
Zippy's Avatar
If I put spinners on, do I have to make an adjustment to the coil overs?
Old Sep 13, 2005 | 03:22 PM
Ruiner's Avatar
No, but you will have to make an adjustment to your head when someone from 6speedonline smacks you upside it for doing so.
Old Sep 13, 2005 | 03:46 PM
Zippy's Avatar
Really? I thought the spinners comment might get a reply
BTW thanks for your prior comment. I look forward to your findings.
Mike
Old Sep 13, 2005 | 10:00 PM
Zippy's Avatar
Dudes. Those little turn ***** on the ends of the coil overs. Anyone ever make any adjustments?
Old Sep 13, 2005 | 10:18 PM
Ruiner's Avatar
My front is as 5 I do believe and things seem a bit jittery in a way. Very touchy. My rear is at 8. I am going to tighten them both and see how that firms things up.
The problem is that I do not have the GT3 sway bars. That adds another variable that I can't account for.
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
ECS Tuning - VW
Aug 25, 2015 02:54 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 18, 2015 01:04 PM
