Engine Cover Latch
Old May 4, 2014 | 05:49 AM
dhc3's Avatar
dhc3 is just really nicedhc3 is just really nicedhc3 is just really nicedhc3 is just really nice
Engine Cover Latch
When I activate the release from inside the car, I can hear what sounds to be the lock on the latch unlocking, then locking itself again before I can get to the rear and open engine cover. If someone else activates the latch and I am standing at the rear and lift engine cover, it opens just fine. Any ideas on this?
Old May 4, 2014 | 06:08 AM
32krazy!'s Avatar
sounds like a microswitch is bad. same thing happens to the doors on these cars regarding the window opening and closing when the door latch is grabbed
Old May 4, 2014 | 06:53 AM
redturbo01's Avatar
redturbo01 is infamous around these parts
I have the same issue. How do we fix this issue?
If I use WD40 on the latch it will work for a little bit and than it goes back to doing what it did....
Old May 4, 2014 | 08:09 AM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
On each side of the deck lid, there is a black plastic/rubber stop. They are threaded. If you twist them out in small increments, while opening/closing the lid, it will pre-load some pressure on the latch.
Old May 4, 2014 | 11:34 AM
redturbo01's Avatar
Good call!
I will try that and keep you posted....thanks.
Old May 6, 2014 | 04:39 AM
dhc3's Avatar
Yes, I will try that today. Thanks!
Old May 6, 2014 | 05:47 AM
dhc3's Avatar
That was the fastest and easiest repair in the history of automotive endeavor! Not even a 1/4 of a turn fixed it. Awesome, thanks!
Old May 6, 2014 | 07:02 AM
Vantaredoc's Avatar
👍 anytime!
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
LiquidElephant
Aug 27, 2015 06:17 PM
trek737
Aug 23, 2015 08:12 AM
JMon
Aug 21, 2015 08:20 AM
