Tech help please!!
Old Sep 16, 2005 | 07:00 AM
Rave TT's Avatar
Happy Now?
Rave TT is a jewel in the roughRave TT is a jewel in the roughRave TT is a jewel in the rough
Question Tech help please!! Jack and stand question
I need to take all four rims off and leave the car on stands for a day or two, where do I jack the car up from to have a place to put the stands (front & rear), pics would be greatly appreciated.
Thanks.
Old Sep 16, 2005 | 07:15 AM
buddyg's Avatar
No pics but if you get down on the ground and look under the car you will see the jacking points. Get your manual out and look there too. Right behind the front wheels and right before the rears.
Old Sep 16, 2005 | 07:44 AM
Rave TT's Avatar
Happy Now?
I know how to jack up the car but while it is up on one side, where do I put the stands? and so on for each wheel.
Old Sep 16, 2005 | 08:41 AM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
I recently did that to my car and put the 3 ton jack stands on the suspension carriers, I have two race jacks for that reason so I can completely jack up the car front or rear and than strategically place the stands in the appropriate locations. (use the regular jacking points on the car like you normally do to jack the car up) I did the rear first and then the front.
It will become obvious when you jack the car up but is much easier and safer with to jacks IMO.
The last thing I wanted to happen was it slide off one of the jack stands when I was jacking the other side up. These cars are so rigid that you can almost jack the car up on one side and that whole side will come up front and rear at almsot the same height off the ground. For the cost of them buy two decent aluminum race jacks and you will be good to go and feel more comfortable about it.
Hope that helps some.
Old Sep 16, 2005 | 09:44 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Actually they are that rigid, or at least mine is with aftermarket anti-sways........I'm able to take the back left up enough to get the jack stand under the left front.
Steve Jarvis
Apr 1, 2023 06:49 PM
pwdrhound
Sep 13, 2016 10:44 AM
freddiemac
Oct 7, 2015 11:05 AM
drkbrent
Oct 1, 2015 07:30 AM
rakka
Sep 23, 2015 08:46 PM
