Slight hesitation on low rpms
Thanks for the bump. Almost forgot this thread. My issue ended up being my fuel lines inside the tank. When at idle it was fine, but when you step on it, it fell on it's face. Swapped pump and lines and now it responds much better.
This sounds exactly what plagued me when I first bought the car. No codes - just hesitation when you touched the gas at slow speed. RPM would drop a bit before the power came on. It lasted for months until I got pissed off enough - one day I just floored it when it happened and I finally got a misfire code that told me what cylinder to focus on.
In the end, I bought BBI coils and haven't had a problem since.
check the voltage of the 2 accelerator pedal position sensor values and the 2 throttle potentiometer values with durametric "actual values"
do it during a testdrive and look at the oszillogram on the screen during the situation at the issue...maybe you see the failure at the moment it exist with a reaction at the voltage results
Still have the same problem.. Haven't had much time to do any logging unfortunately.
DV= Diverter valve. The 996 Turbo has two, that divert turbo pressure back to the intake when you go off the throttle. Prevents compressor surge.
MAF = Mass Air Flow sensor. Measures the amount of air going into the engine. Is mounted in the pipe directly after the air filter.
I've had the car in for diagnostics at the local Porsche dealer and the preliminary conclution is that my car is one of now three in Europe with this issue. The solution in the other cases has been a new DME, at 4900 usd...
Checked for leaks at high pressure, nothing major, held pressure for almost a minute. Pre-turbo intake is difficult to check as most piping is well hidden. Also, are you sure it's related?
Let me repeat something from the first post:
The problem is a slight hesitation when getting back on the throttle at low rpms that's been getting progressively worse. Most noticeable in 1st and 2nd gear. I apply a bit more throttle to accelerate but the car seems to cut for half a second before pulling its **** together and giving me some power. It happens at low rpms, so I guess it's not boost related.
It always happen between idle and 2000 rpm. Everything is fine above 2000. Also, I've noticed that when I get back on the throttle the oil pressure dips for half a second. Is that normal or perhaps related to this?
I have the exact same problem/issue...It happens when I re apply a small amount of throttle during casual in town driving. It's like it momentarily cuts off. If I mash the throttle it does not happen. It is very annoying as it make the transition from off throttle to on throttle very jerky.
Come to think of it, I recently installed an aftermarket MAF. I have notice the throttle response has been twitchy/over sensitive since the new non OEM MAF.
I've also experienced a feeling of a fluttering throttle plenum. If I accelerate through the gears at a very small throttle position, say 1/8 throttle or less and let the car rev up to 3k to 4k, it feels like the throttle plenum is moving even though my foot is not moving on the pedal. The acceleration is not smooth. It feels like the ECU is changing its mind and changes the throttle opening +/- . Only happens at very light throttle application. Thankfully, I am rarely at 1/8 throttle
I'll try the old MAF and see what it does.
