Camber arms don't fit...??? (2002 Turbo)
Old May 20, 2014 | 09:47 PM
lobuzz311's Avatar
lobuzz311 has a spectacular aura aboutlobuzz311 has a spectacular aura about
So I'm in the process of installing coilovers, and I ran into an issue. It's past business hours, so I was hoping to see if anyone here had any ideas before I get to call tomorrow morning.
I ordered Torque Solution camber arms to deal with the alignment issues after lowering the car, but the bushings are too wide to fit into the mounting location. My confusion is that ALL 996 & 997 models are listed for these arms, yet I can't see how they possibly would fit...
Here are some pictures showing the difference in width & lined up to the mounting location.
Any thoughts?
ID:	376958   Click image for larger version
Old May 20, 2014 | 10:05 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
The "high misalignment bushings" (that's what they are called) in your rod ends are obviously too long. Check and see if all 8 are the same width. It's not critical on the other end, only for the clevis in your second pic. If you have some narrower bushings included, swap them around. If not the Mfg screwed up. You might also check and make sure there is very little play between the bushings and the bolt. I made my own dog bones and sleeved the bushings from 1/2" to 12mm for a precise fit on the ID.
Old May 20, 2014 | 10:10 PM
lobuzz311's Avatar
Yeah, I was hoping there were some narrower bushings, but they are all the same width.
I did notice that it doesn't really matter on the other end, since the width can vary, but obviously they are not going to fit into the clevis (learn something new every day) as is.
Old May 21, 2014 | 11:34 AM
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
What is the total width on the original part??
Old May 21, 2014 | 11:48 AM
lobuzz311's Avatar
Not sure. Don't have the part on me. Torque Solution is over-nighting new flutes to fit so I should be good.
2lflat4
Nov 18, 2019 05:05 PM
SharkyShark20
Sep 19, 2015 09:54 PM
VGLNTE1
Aug 20, 2015 08:14 PM
TrackOne
Aug 20, 2015 12:56 PM
Aug 19, 2015 06:35 PM
