First Porsche
Old Jun 17, 2014 | 09:29 AM
evilruss's Avatar
evilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud ofevilruss has much to be proud of
First Porsche
Just picked up my first porsche last week. It's a yellow 2001 996 Turbo with 32,000 miles completely stock. Already addicted to the drive. Totally different experience from all the other cars I've owned.
Old Jun 17, 2014 | 09:35 AM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
Welcome..............tons of knowledge on this forum. Just watch out for that slippery slope called PPPOOOOWWWAAA on this platform. Lol. Enjoy, its a great car.
Old Jun 17, 2014 | 09:48 AM
evilruss's Avatar
Thanks! Still waiting to get the maintenance records for the car but will probably get it on the lift soon and do a plug change. Feels like it has a slight stumble when cruising at just over 3000 rpm's. And the leaky rams on the spoiler. Already downloaded the pdf service manual. Still love my GTS but I can already see this car cutting down the mileage the viper sees.
Old Jun 17, 2014 | 09:51 AM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
Congrats and welcome! I traded for mine to re-sale but now addicted! I'll be keeping the yuppie machine for a while now..lol
Old Jun 17, 2014 | 10:42 AM
The leaky spoiler is a common problem. With a quick search you will see there are a lot of things you can do to permanently fix it. One being a fixed wing position with bars.
Old Jun 17, 2014 | 10:49 AM
rmc1148's Avatar
Sounds like a nice low mileage car welcome.
Old Jun 17, 2014 | 10:52 AM
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
...Already addicted to the drive. Totally different experience from all the other cars I've owned.
Gotta be the color.
...Feels like it has a slight stumble when cruising at just over 3000 rpm's.
That's probably the well-known variocam "feature" you're feeling. Search for it and you'll find more than you'll want to read.
Congrats on the purchase and enjoy it! Stick around here too, lots to learn and contribute!
-V
Old Jun 17, 2014 | 12:36 PM
evilruss's Avatar
Looked at a couple threads so far, one being the fluid mix with sealer. I kinda like the automatic spoiler so I'll probably give that a try and see if it helps stop the leaking. It only threw the malfunction light when I test drove the car. The seller had it checked out by a local shop that said the pump needed replacing. Maybe just was getting low from the leak. I'm not sure if they added any fluid or not though. It hasn't done it since and I've put about 700 miles on already so I'm thinking it might not actually be the pump.
Old Jun 17, 2014 | 12:40 PM
evilruss's Avatar
Originally Posted by Vendetta
Gotta be the color.
-V
LOL, I absolutely love the yellow! I wasn't going to actually try to buy one until next spring but this was the exact car I was looking for that showed up local so I went for it.
I'll check into the variocam and see if that might be it. It seemed very consistent when holding around 3050-3150 rpms that it would kind of stumble or vibrate a little. Didn't seem like the normal symptoms I've run into with previous turbo cars that needed plugs or wires in some of the cases. Figure either way if the plugs haven't been replaced on the car yet might as well get some fresh ones in there.
Old Jun 17, 2014 | 01:07 PM
evilruss's Avatar
Couple of pics
ID:	388479   Click image for larger version
Old Jun 17, 2014 | 02:45 PM
Mish_Mish's Avatar
Mish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud of
Is fabulous color combo you have there, my friend.
Old Jun 17, 2014 | 02:49 PM
'02996ttx50's Avatar
96t is a helluva 1st 911. congrats
Old Jun 17, 2014 | 02:51 PM
Mish_Mish's Avatar
It is like having .50 cal first firearm, I did the same thing and do not regret at all.
Old Jun 17, 2014 | 03:58 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
You picked the best color. Now time for you to get carried away and mod the crap out of it...
Old Jun 18, 2014 | 03:53 AM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
You can run the spoiler up and down with a battery charger once the wires are disconnected at the pump motor leads. The refill procedure is not easy, just a pita if you ask me. My motor was seized up, once that was fixed and reservoirs filled with straight PS stop leak and bled, she worked fine. Be careful with the microswitches, they are mighty delicate...ha ha
