The time has come, CLUTCH!
Old Jul 5, 2014 | 08:33 AM
Mish_Mish's Avatar
Mish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud of
Dear fellow turbo owners,
My clutch is not slipping, but seems to be original, with 58K miles on it, so time prepare.
Please suggest what are the best clutch options for the reasonable money?
I think I'd prefer to go single mass flywheel and probably OEM, or similar to OEM pedal stiffness.
Perhaps someone has good used flywheel from upgrading to stage 3/4/5+ clutches?
Link to good supplier is also appreciated.
So far I found OEM German made kit for $728 on eBay, this is about it.
Old Jul 5, 2014 | 08:43 AM
'02996ttx50's Avatar
a properly driven car with no obvious abuse to the clutch *should* last you another 100k miles. at least. there a lot more things i'm sure you can replace that would improve the car, if you are going to begin throwing parts at it, as we al all known to do
but the car is "broken in" at 30 k miles and you have a 58k clutch! just failing to see the problem here lol.
why not just give it a 90k service ( plugs/coils/coolant/brake fluid etc etc )
Old Jul 5, 2014 | 08:47 AM
Mish_Mish's Avatar
I do not like how it grabs toward the top and I have suspicion that auto transporters might have overheated it, when they loaded car from Miami, I was not there...
Anyways, I will be lowering assembly soon, so why not address the clutch.
Lastly, this thread is not for discussing my personal decisions, but to help me locate best parts at a reasonable rate.
Old Jul 5, 2014 | 09:02 AM
of course it is lol it's an open forum and "your personal decisions" are fair game.
but you "think"? they overheated it loading onto a truck so you think you should replace the clutch? lol ok sure. have at it.
btw. responses may not be to your liking. so suck it up..lol. and have a nice day
Old Jul 5, 2014 | 09:19 AM
TeCKis300's Avatar
TeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of light
I 2nd the thoughts of above.
Slipping the clutch at low speed onto a transporter is not going to burn out the clutch. The clutch can take that abuse with ease (if it even happened).
That said, if you must. Are you planning to make more power? Or is this just preventative for longevity, sorta 'while you're in there'?
You can just change the major wear components if all is working well and there's no signs of abuse to the flywheel or pressure plate. Slap in a new disc and release bearing and call it a day.
Old Jul 5, 2014 | 09:23 AM
TeCKis300's Avatar
I'm currently dropping my tranny to change a slipping clutch. In my search for parts, Gaudin Porsche seems to have great pricing - http://www.gaudinporscheparts.com/pa...section=CLUTCH
Old Jul 5, 2014 | 09:36 AM
An excellent mid level compromise is the oem clutch with the gt2 disc. Exact OEM feel because it is. The gt2 disc will handle 500 whp. Cheers.
Old Jul 5, 2014 | 11:17 AM
johnspeed's Avatar
Almost Same fell with the Sachs Performance clutch set up and will hold more power,,I have it my car and its great and I am at 600plus a few rear wheel.
Old Jul 5, 2014 | 12:13 PM
Mish_Mish's Avatar
These are good prices, thank you!
Old Jul 5, 2014 | 12:14 PM
Mish_Mish's Avatar
Do you have part number, or link to your clutch set?
Old Jul 5, 2014 | 12:15 PM
Mish_Mish's Avatar
Do single mass, lighter flywheels bring any stalling issues on take off?
Old Jul 5, 2014 | 12:36 PM
johnspeed's Avatar
Check Sunset Porsche out, they always have had the best pricing for me.
Old Jul 5, 2014 | 02:00 PM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
Single mass lwfw will be noisy at idle, if you are planning on HP mod and mad runs at 60-130 times and 1 and 2 miles top speed challenges, go for it. If you are planning to sprint around town with mild k16 tune, stay with dual mass and new clutch. Trust me, you will appreciate it
And while you are at it, GT-2 slave conversion too will keep you from bleeding later.
Old Jul 5, 2014 | 03:28 PM
i almost went with the sachs 2.5, which i am told is even next level up from oem w/ gt2 disc, but i'm perfectly happy with the gt2 disc w oem plates. you have a bit more power, but i have less room to use mine in so it evens out lol
in fact, in two cars, i've never had a clutch issue but was about to! my plates had zero material left when i went into the trans. but never did it slip
Old Jul 5, 2014 | 03:32 PM
some folks have had stalling issues until they get used to the lwfw i am told. but this is anecdotal, as i haven't done the lwfw as i've added enough NVH to my car as it is lol. though i'm sure i would love the faster revving. everything is a trade off i suppose.
