radio noise. need help!!!!?
Old Jul 23, 2014 | 02:43 PM
Drew959's Avatar
Drew959 is a jewel in the roughDrew959 is a jewel in the roughDrew959 is a jewel in the rough
Originally Posted by bmwtmx
My car makes a high frequency noise through the speakers even if the radio is off. Same reason? I have an aftermarket Kenwood head unit and different amp.
You guys are most likely getting alternator whine, especially with aftermarket equipment. A ground loop isolator will fix this.
Old Jul 23, 2014 | 02:50 PM
bmwtmx's Avatar
bmwtmx has a spectacular aura aboutbmwtmx has a spectacular aura about
Is there a particular one to buy?
Old Jul 23, 2014 | 03:31 PM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
Check your ground and try different ground location first. Ground loop isolator will also add distortion to your sound system.
Old Jul 23, 2014 | 04:55 PM
Drew959's Avatar
Sure check your wiring first. Also, if your stereo/amplifiers are aftermarket you need to run your power wires on different sides of the car. This is a harder install but helps against whine / interference.
Many many people use isolators with great success and no noticeable increase in distortion. I sold car audio for a few years back in the day, I never had people return them. Do a google search and read reviews. Keep in mind you can pick up an isolator for $20 or so from Best Buy or Radio Shack. If you don't like it or it doesn't help it's easy to return.
Old Jul 23, 2014 | 05:37 PM
wross996TT's Avatar
The OP has a stock stereo...there is no need for a ground loop!
Old Jul 24, 2014 | 04:59 AM
mlally541's Avatar
mlally541 is infamous around these parts
correct, with me having a stock radio and amp i shouldnt have to add a isolator mine problem is gonna be a bad ground somwhere. gonna look at it this weekend and ill get back on to post what i find.
Old Aug 25, 2014 | 10:38 AM
mlally541's Avatar
Thumbs up
i if bang the dash board above the radio the noise stops. i ordered radio tools to get the radio out pretty sure its gonna be a bad/loose ground in there somewhere. ill let you guys know what i find when i get the radio out.
vpr80
Mar 6, 2021 12:11 PM
7thsign
Dec 12, 2015 07:43 PM
alpha motoring
Oct 2, 2015 12:04 PM
Mz3bo
Oct 1, 2015 06:32 PM
TypeRx
Sep 28, 2015 08:24 PM
