Roll Bar Nightmare
Old Nov 12, 2003 | 10:26 AM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
Originally posted by watt
ask Oak for help:
you cut a notch in the plastic underneath the carpet where the foot of the rollbar goes to the outside of the car, so that the rollbar sits in the notch. this makes the long bolt easier to align and put in.
much more satisfying than fighting to do it without cutting plastic.
when you sell the car you can replace the plastic piece under the carpet.
Good/correct advice to make the job easier -- the replacement cost for the plastic piece is also inexpensive.
Old Nov 12, 2003 | 10:30 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
I was considering that, but I am going to give the crush the rocker panel method a try one more time. I received instructions on how to remove the seat belt height adjuster units from the slider from Loren @ Renntech. With those taken off, I can attach the front legs of the roll bar and use my strength and leverage to rotate the rear legs into position. That will crush the rocker panels. Thanks...I will post instructions w/ pics once the job is done...
Old Nov 12, 2003 | 04:30 PM
dmilzoff's Avatar
dmilzoff is infamous around these parts
Rockitman
I had the same problem when I tried to add a Harness Bar for my camera mount in my 2003 TT. Speak to Bob at STABLE ENERGIES, 973-773-3177. I bought the bar from him and had to go back for him to remove the mounts and bolts that hold in the front seat belt. He did it with a small flat screwdriver, pushing in a metal tab on the left and right side of the adjustable mount. You cannot see the tabs without a flashlight and knowing where they are. He photographed my car and the mounts in and out of the car. He may be able to e-mail you the photos or at least talk you through the disassembly.
David
Old Nov 12, 2003 | 07:56 PM
rockitman's Avatar
The saga continues!!!
Well I was able to remove the belt height slide adjusters...pretty easy, the hole unit comes off...So things are improving. Connected the front legs, went to swivel it back into position, it's gets past the seat belt, then stops....The friggin clothes hook is in the way...no problem, they just popped off. I have one of the rear legs bolted in after much struggle...it seems the orientation of the threads is not exactly perpendicular...whoops, forgot the spacer, out comes the bolt, will be trying this again. My fingers are almost raw at this point trying to get the precision machined bolts started...Well I am going to get the 3rd bolt back in and call it a night...
Man, I am questioning the value of putting a DIY together on this...I don't think I would wish this process on my worst enemy...
"Film @ 11:00" !!!
Old Nov 12, 2003 | 08:58 PM
rockitman's Avatar
Thumbs up SUCCESS!!!!!!!!
Finally, when I was ready to give up, "DA BAR IS IN !!!!". For those who have not done it, you really can't imagine what it is like until you live it. Quite frankly, if you elect to do it by yourself, immediately get an appointment with a psychiatrist. You really need to get your head examined...Although if you chose to accept this mission, when the mission is accomplished, it is more satisfying than sex, IMVHO...The seats go in tomorrow...Thank you all for bearing with me through all my pain and suffering. And for those who offered help and advice, a big thank you....
Old Nov 12, 2003 | 10:21 PM
rockitman's Avatar
Originally posted by 03 C4S
CONGRATULATIONS! Pictures please....
Thank you... I will take pics prior to putting in the seats. Added benefit of the roll bar other than safety, tortional rigidity...Yipppeee!!!
Old Nov 13, 2003 | 01:37 AM
Chris Y.'s Avatar
Chris Y. is infamous around these parts
A write up would be super...I'd be interested since I'm thinking of accepting this mission!
Old Nov 13, 2003 | 05:28 AM
ColorChange's Avatar
ColorChange is infamous around these parts
Rockitman:
As soon as you regain the use of your fingers, please, a full write-up.
Old Nov 13, 2003 | 05:53 AM
KPV's Avatar
KPV
The two that I did took 4 and 6 hours respectively. The 2 additional hours for the second one was due to slightly damaged threads on one of the two front bolts. I had learned a few tricks from first install that I carried into the second install.
In Chris's (Rockitman's) defense, upon speaking with him on the phone, the GT3 does not have rear seat belts so there isn't any point of reference to locate the rear chassis bolt holes under the carpet. That surely made things more difficult.
After Chris posts his DIY, I'll add a few comments on my tricks to supplement it. They wouldn't be as useful standing on their own.
Old Nov 13, 2003 | 06:07 AM
Thanks Ken. I think this will be a big help when I finally get to install my bar when I get my car. I still am thinking of going with the Dasport bar ... looks stronger.
Old Nov 13, 2003 | 05:29 PM
kparis's Avatar
kparis has a spectacular aura aboutkparis has a spectacular aura about
My 4 point rollbar arrives on Saturday and goes in this weekend. I can't wait!! Based on what I read in this thread I immediatly made an appointment to have it installed. I know I'm taking the easy way out but hearing the 4 to 6 hour horror stories scared me away.
I'll be sure to post pictures on Sunday evening.
Old Nov 13, 2003 | 05:42 PM
rockitman's Avatar
Hopefully your dealer has experience installing these. If not stress to them to be very careful. It's easy to damage the interior one way or another during the install. Fortunately for me, I did not damage or scratch the interior and gained some muscle mass in the process...
Old Nov 13, 2003 | 07:40 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Congrats Rockit, What toke you so long man?
Old Nov 13, 2003 | 11:35 PM
kparis's Avatar
The install is being done by a qualifed shop that does lots of racing and has experience putting rollbars in cars. I have a full carbon interior so I'll be keeping my eye on them. They convinced me to let me them do the install. Were actually doing it at the track this weekend here in Florida. Should be fun and I'll take some pictures for everyone to see the process with seats out, etc. With two pro installers that do lots of these it should take them about 2 hours total.
I can't wait!!
Old Nov 14, 2003 | 07:17 AM
rockitman's Avatar
What are they charging for install??? just curious what my efforts were worth
VID997
97
Mar 20, 2018 02:23 PM
maroli
Sep 15, 2015 07:07 PM
JWrightPNH
Sep 14, 2015 01:15 PM
AdamNoone
Sep 3, 2015 04:15 PM
