Maintenance Advice
Old Jul 24, 2014 | 09:27 PM
ramman5600's Avatar
ramman5600 is infamous around these parts
Originally Posted by p556guy
We have similar cars, except mine is an 03 and had the 30k done sometime in 2010.
I thought I had a great car...then I did the MAF, plugs, coils, and o2 sensors...I literally almost can't believe how much better/smoother it runs.
Did you have an codes showing prior to the change?
Old Jul 24, 2014 | 09:41 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
For 1000 mile trip I would be more concerned over tire wear, make sure the alignment is proper, you'd be surprised how road trips eat tires on these types of cars, depending on ur tire you could be bald by the end of the trip.
Fluids and plugs are the main prep for a road trip,
Old Jul 24, 2014 | 09:43 PM
p556guy's Avatar
p556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud of
Only for O2 sensors. If I had to complain I would say the car would hunt for idle once in a while on cold start, and my first time getting into second gear on a cold motor from a full stop it would bog/stumble really slightly.
I had planned to only swap coils if mine looked bad. Some had cracks and it was a mis-matched set of part numbers so I put in new ones.
Also fixed a small boost leak and now the motor holds revs better between gears.
These cars were built to be run 200,000+ miles in harsh german winters. I'm sure the OP will be fine
Old Jul 25, 2014 | 01:47 AM
waynerosebmw's Avatar
waynerosebmw is infamous around these parts
maintenance advice
Great road trip car-just completed 6000 mile trip west tp east.
Check rear tires- inside ( I didn't check mine close enough-looked great from outside but after 1500 miles had cords showing on very inside-very lucky to have stopped for service and it was discovered.
Good advice on oil and other things -I keep coolant/acc.belt/oil/s.plugs/glass cleaner for w/shield/ but only used oil ( about 2 quarts on trip)
Recommend good visual check prior to trip.
Check tire inflator pump (mine was seized -probably never used)
have a great trip-enjoy the ride
Old Jul 25, 2014 | 04:46 AM
dhc3's Avatar
dhc3 is just really nicedhc3 is just really nicedhc3 is just really nicedhc3 is just really nice
On a recent PCA weekend road trip I hit a massive pothole and had a rear tire blow out at 90 mph. Probably my only road trip problem ever. In the event of something like this, a charged cell phone is a good thing. Familiarize yourself with the inflatable spare and tools.
Have a great trip!
Old Jul 25, 2014 | 06:21 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
boost leak test, check tires, coolant level, oil level and go.
JQGS
Oct 18, 2015 06:19 PM
saiko88
Sep 11, 2015 02:17 PM
