996 Trans - which oil
Old Sep 3, 2014 | 11:40 PM
0396's Avatar
0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute
First, to my knowledge this has bee discussed in the past- I attempted the search and came up empy.
Now the question, I've had some work performed on my 996's trans with factory LSD.
The tech / owner suggested that I replace it with dyno - Swepco 212.
I mentioned,...it's all stock and to my knowledge everyone replace fill with M-76/90 syn.
Should I try this Swepco or simply stick with 'factory' recomendations on using a syn type of trans oil?
Thanks in advance for your suggestions
Old Sep 4, 2014 | 08:15 AM
'02996ttx50's Avatar
anytime you run an lsd you need to use trans fill that doesn't contain any "friction modifiers". so the best bet would be m1 delvac 75/90 which is without them.
if stock w/out lsd i would use the redline 75/90.
Old Sep 4, 2014 | 08:46 AM
0396's Avatar
Thanks for the confirmation. Now where can I pick up M1 75/90 in the required amount ...4qts or so in the Ontario Calif /IE?
Any suggestions ?
Old Sep 4, 2014 | 09:14 AM
Any suggestions ?
i would guess? it can be found at most any of the "larger" auto supply places. barring that, pelican parts is local so even if they had to ship it, it'd be next day. search their site and see if they carry it or call pep boys/napa et al
the shop i use just picks it up as needed. i've never filled on my own.
Old Sep 4, 2014 | 09:15 AM
0396's Avatar
I think I've found it at a truck stop..question. How much does the 996 trannie need?
Old Sep 4, 2014 | 09:33 AM
*about* 4 qt's but check the manual or the pdf online to be sure.
btw.. what "factory" lsd do you have installed?
Old Sep 4, 2014 | 03:08 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
I have used both Delvac and Redline. For me the Redline seemed to shift smoother. Mind you this is just normal street driving.
I didnt know an LSD was a factory option. How do you tell if you have one?
Old Sep 4, 2014 | 03:51 PM
johnspeed's Avatar
I am a Redline type of guy only.
Old Sep 4, 2014 | 05:29 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
I've got Delvac for my GT2, betting OP also is running a GT2...
Old Sep 4, 2014 | 06:19 PM
Makes sense.. Given the mention of factory lsd
I think LSD vs none should properly affect ones decision to use delvac vs redline. "Friction Modifiers" again.
Old Sep 4, 2014 | 09:24 PM
993GT's Avatar
Ideally, for most Porsche boxes(transaxles), you don't want friction modifiers LSD(which most 'traditional'/'old-school' lsd's want) or not, sychros need to be sped up and the modifiers play a negative role
Buy a quality fluid and change regularly
Old Sep 5, 2014 | 12:20 AM
0396's Avatar
Guys, yes on the GT2 and just upgraded the 'guts' of the OEM LSD to Guard parts.
I ended up locating a gallon of M1 Delvac 75/90 for the refill.
I'm looking foward to the new set up. Simple ERP toes, corner balance, up graded internal Guard LSD parts and alingment.
All for the street.
Old Sep 5, 2014 | 04:46 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Thumbs up
All for the street.
Nice
Old Sep 5, 2014 | 07:43 AM
Mobil 1 Delvac
#TeamAIM
nlakind
Nov 6, 2015 10:15 AM
carwash
Sep 29, 2015 10:43 PM
pshep138
Sep 1, 2015 09:45 AM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
