Looking to replace my Clutch Slave Cylinder/Accumulator
Old Sep 16, 2014 | 11:53 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
can you guys provide parts - numbers for gt2 conversion? I'm going to look into it, screw this poor design crap, do it ones and do it right. I can buy used 996 with acc for very good price, just so it gets me through winter- and change it to gt2 if it fails again, which I know it will. --
I found one here, let me know guys if the price is right : http://www.evoms.com/EVOMS_GT2_Clutc...clugt2slck.htm
Old Sep 16, 2014 | 11:59 AM
Slider's Avatar
This is what I bought from Pelican parts and everything dropped into place...
Item Part Number Qty Description
1 996-116-237-90-INT 1 Clutch Slave Cylinder
2 996-355-119-01-OEM 1 Master Cylinder Brake Fluid Reservoir Cap, 996/996 Turbo 1999-2004, Boxster/Boxster S 1997-2004
3 996-423-081-18-OEM 1 Clutch Power Spring on pedal cluster
4 996-423-171-06-M33 1 Clutch Master Cylinder, 996 Carrera 2/4 1998-04, Boxster/Boxster S 1997-04, Each
5 996-423-377-90-M100 1 Clutch Fluid Hose Clutch Slave Cylinder to Fluid Pipe
6 997-116-086-90-M260 1 Release Bearing Fork
Old Sep 16, 2014 | 12:57 PM
MadWhip's Avatar
Thank you !
Old Sep 16, 2014 | 03:59 PM
p556guy's Avatar
p556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud of
What's the cost for parts+labor on both options?
I was out of town for 2 weeks. When I got back into the 996 my clutch pedal was so stiff it wouldn't move more than a few inches. I'm assuming this will keep getting worse until it leaves me stranded?
Old Sep 16, 2014 | 04:29 PM
Slider's Avatar
It was $600 exactly for what I listed above. There will be some fluids to replace in there as well. For labour - that totally depends on who does it. I would expect 6 hours from someone who knows what they are doing. (Longer or shorter if they don't)
Old Sep 16, 2014 | 04:52 PM
32krazy!'s Avatar
everything you need to know about the conversion
https://www.6speedonline.com/forums/...onversion.html
Old Sep 17, 2014 | 07:49 AM
MadWhip's Avatar
local indy shop in IL wants to charge 6 hours, 125 per hour. I never left my car for several weeks so i cannot tell, but i think when slave goes bad, its building pressure overtime, thats why. Maybe I'm wrong.
Old Sep 17, 2014 | 08:04 AM
MadWhip's Avatar
So I purchased slave and acc, cheap from 32krazy! IT be temp fix, when that one fails- I'm going with gt2 - by the way Do i need bleeder to - bleed out the clutch, Ill try to bleed my clutch first. I can get assistance to help me to press the clutch pedal. while I'm laying on my back---to play with bleeder
So procedure goes like this? you pump the clutch few times, hold it, and you release the valve, on slave. and repeat 20 times probably?.... - or if you have power bleeder you dont have to pump the clutch?
Also now I remember when I posted something on here about the leak--- I still have picture: Name:  MLI8Pyp.jpg
Size:  17.6 KB I thought it was leaking from that bolt, or axle/seal but i think it was from slave. It stopped. It got dry, i never bothered, after changing the clutch to aftermarket one, it started to **** me off with the take-offs- where clutch is soft when car warms up and grabs up top, I drove many cars and owned cars with aftermarket clutch. everything else seems fine and i dont see any leaks from reservoir or level changing...
SharkyShark20
Sep 19, 2015 09:54 PM
The Oss
Aug 24, 2015 08:19 PM
cerbomark
Aug 22, 2015 12:50 PM
TrackOne
Aug 20, 2015 12:56 PM
