Mapping Q regarding larger plenum and TB
Old Sep 18, 2014 | 07:20 AM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Good idea, the MAF is brand new I had to put a one way valve between the oil tank and the plenum because the IPD comes with a seperate one and that had been removed, maybe I have another missing
Old Sep 18, 2014 | 08:25 AM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
The check vslve between the plenum and oil tank is the one you have to worry about.
Even with a check valve, the flow could be too much and as fadi said, you probably need a restrictor between the check vslve and oil tank.
I used an 8mm "grub screw" (atleast that's what they are called in Australia) and then drilled a 1.5mm hole in the center (from the hex all the way thru).
Then just install it in the rubber pipe between the check valve and oil tank. This fixed my high idle
Old Sep 18, 2014 | 09:03 AM
OK good shout so if I clamp the pipe temporarily that will tell me if thats the problem
Old Sep 18, 2014 | 01:08 PM
def an air/vac leak. smoke test it.
#TeamAIM
proTUNING Freaks
15
Jun 30, 2016 08:05 AM
drizcol
Cayenne 955/957
Sep 27, 2015 09:12 AM
Mdebrouwer
Merchandise For Sale / Wanted
Sep 22, 2015 04:46 PM
albert@velosdesignwerks
Sep 3, 2015 11:11 PM
