Is a PCM swap plug and play?
I have an 04 996 Turbo with PCM and have disconnected the battery numerous times and never had to put a code in. I have read that with Carreras there is a requirement to in put a code if the battery has been disconnected, but can't confirm if this is the case. It could also be that the PCM is linked to the ECU so as long as they match there is no code needed but I don't know. I'm sure someone much more knowledgeable will know.
I'm not 100% sure but I don't think the 996 was offered with a non Bose PCM 2.0.
