Is a PCM swap plug and play?
Old Sep 27, 2014 | 07:59 PM
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
I want to retrofit one in my 03' Turbo, but need to know exactly what is needed and if possible.
Old Sep 28, 2014 | 11:44 AM
IITURBO's Avatar
no one?
Old Sep 28, 2014 | 05:09 PM
IITURBO's Avatar
Someone has to know lol i remember in my audi it was plug and play, just needed to tap into a speed signal and install the gps antenna.
Old Sep 29, 2014 | 09:26 AM
IITURBO's Avatar
Bueller.........Bueller...........Bueller......... ...................
Old Sep 29, 2014 | 07:55 PM
IITURBO's Avatar
at least a yes or a no, someone has to have an answer.
Old Sep 29, 2014 | 08:05 PM
rmc1148's Avatar
I have no idea but agree someone else has the answer =good luck!
Old Sep 30, 2014 | 02:09 PM
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
this is not what called "plugnplay" if you need to add something
Old Sep 30, 2014 | 07:31 PM
IITURBO's Avatar
You're not helping lol
Old Oct 2, 2014 | 07:20 AM
IITURBO's Avatar
bump
Old Oct 3, 2014 | 12:58 AM
Serg124's Avatar
think about adding some more info of what you have and what you want to, photos, etc. for now you question is "who can tell EXACTLY is there life on Mars?"
Old Oct 16, 2014 | 06:08 AM
IITURBO's Avatar
Bump, just trying to find out if I can swap in a factory PCM from Ebay into my 03' which doesn't have factory PCM. Any coding or special wiring needed?
I want to go from this:
To this:
Old Oct 16, 2014 | 08:34 AM
antagron's Avatar
antagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant future
The wiring is fiber optic for the bose MOST systems who his why you can't simply swap head units from PCM to aftermarket. I have a PCM head unit and amplifier available if you want to avoid eBay but I don't have any of the wiring between the amp and the head unit. Not sure what happened to it (reused or discarded by installer). Pm me if interested.
Old Oct 16, 2014 | 11:42 AM
Serg124's Avatar
To this:
no. just plug it. as I see all matches. just add gps antenna. and radio antenna plug adapter. if first photo doesnt match your car - make yours and place it here.
Old Oct 16, 2014 | 11:43 AM
Serg124's Avatar
Old Oct 17, 2014 | 06:14 AM
IITURBO's Avatar
Thank you Serg! I pulled the trigger on a mint PCM2 for 500 bucks which also comes with the amp. I'm sure I'll still have to unlock it or something to get it working in my car, there has to be some kind of anti theft coding.
