2002 996 tt possibilitys
Hello im looking at buy car with these moods K24 TURBOS - GIAC ECU TUNE(1.2 bar tp 1.6 ) - FABSPEED CATS AND EXHAUST - BILSTEIN Coilovers - DIVERTER VALVES - HOSES - INTAKE - ETC What kind of hp will it make and is there any easy hp gaining mods for this car at this stage! Its suppose to making around 540 hp ,im wondering what 650 will take? Also being setup with awd and auto trains is it safe to go up to 650, with damage ,should a knock sensor be added?
:eek :
mjg
:eek :
mjg
:eek :
mjg
:eek :
mjg
I think you're right on the money with those mods making 540 crank.
The tiptronic (Auto) trans will handle 650crannk no problem. To get there you would need to send the k24 in to be rebuild with an 18g billet wheel. I recommend 911tuning.com for this.
For 650 crank you would need to do the following mods at MINIMUM:
- Hybrid k24 turbos (k24/18g billet) or go up to a tial turbo like the A28 (A28 is more expensive but a better turbo in general)
- Bigger intercoolers, I recommend the gt2rs factory intercoolers.
- Retune from a reputable tuner. Read some threads about tuners.
- Injectors. I think Markski/911tuning only tunes for the 60/72lb injectors, but the 80lb injectors are great too. Mine Idle perfectly.
Good luck!
I do , i need a few other things as well ,no kidding lol ! Thanks for the reply ,if the k24 are bolt on and mods, id think they would have modded compressors... possible already ,unless these are stock Ts. What is the stock turbos used ,if the car is capable of running at 1.2-1.6 bar than something would of been modded, possible coolers and other suff ,Y/N ? The guy who is selling car said mods are done by redline/evoutiom motorsport ! TabooPc so are you saying giac is not at top of your plan of attack of the ecu, not who u would use ?. If i get this car i would like to some up to the abilities as Todd at Promotive Engineering or possiblly Jay Richardson of the old RPM in Fl. Daytona area! The only prob. is no dyno, i would think with the internet these days it could be tuned remotely via computer, online. So if anyone can read what i cant ,with reguards to the listed mods ,is the thought of TabooPc the easyiest way to pull 600+ hp out of this screamer or would you think the easy thing have all been done.? i read here or on another knowledge filled site that 700 hp was some what do able with out the intercooler being replaced and any internal work,example cam profiles, crank shafted knifed and head porting. ???s Like i say the guy selling it was all holidays and wont be back till Monday! Oh one more do they still use knock sensors on these new models ,back in the eightys the jb sensor was the one used by the guys in the know to retard the timing at any sign of trouble . It maybe built into the ecu managment system Thanks MJG Would stock injectors be able to supply enough fuel for the required quest?
:eek :
mjg
:eek :
mjgWallbro intank FP for E85, ID 1000 injectors, AWE race exhaust, RWD conversion with Ohlins coilvers, upgraded clutch etc, pro tune with Eurodyne
You may get there with adding the injectors, new tune and intank FP, GIAC has a race gas tune as well so all those would get you there without the need for billets but you will then be borderline on IATS so I would then add ICs and at that stage what is another $2500 for 68mm HTA K24 billets
BTW if you hit 1.6 bar that would probably mean you have the billets already or an aggressive race gas tune. At 1.3 bars max I hear my stock WG's popping so you may have aftermarket WGs already as well
Thanks guys for the knowledge and our responces ,would a knock senor not save it from Karboom! Id think i would leave it at 1.0.-.1.2 for saftey reasons, that seems like it would a lesson i would want to think about unless it can be forced without the risk of disturction!and it doesnt seem fesable ,or is there a safer way! jb knock sensor? thanks mjg
Im guessing on the modds !
If Redline did the mod than i would think that the Turbos have been modded and the intake is 3", now the ics are .or must of been done , because of the high boost possibilities ,unless the guy had a plane and endless fuel,and if evo /redline did this and 550 hp was reached than it just may has stock injectors and fuel pump. lots of if but butt butttts , what would this all cost to have the work done and ecu programed and dyno done and the parts as well? Is this car with 92 k on it and 30 k after the build worth 48k ,pending everything is right!
Thanks MJg
Thanks MJg
:eek :
mjg
:eek :
mjg
Baseline is stock + hardware uprades. A true stock baseline would be much lower.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
carwash
Sep 29, 2015 10:43 PM
