Problem with Oil Level indicator,Please help
Old Nov 12, 2014 | 11:56 PM
dominik...'s Avatar
dominik... is infamous around these parts
Hello,
I have a problem in 996 Turbo with oil level sensor ,
I have message on cluster "Oil level indicator failure"
We replaced oil level sensor and oil pressure sensor and still nothing.
Any advice where could be a problem?
I have the message "Oil level indicator failure" just after oil warmed up
Thanks for advice
Rgs
Old Nov 13, 2014 | 06:07 AM
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
Could be a wiring issue
Old Nov 13, 2014 | 11:40 AM
602996TT's Avatar
602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future
It could be your gauge cluster computer is fried I once had the unfortunate situation of having my battery installed backwards and it fried my ability to check the oil level, North Hollywood Tach replaced my gauge cluster computer for $750. But always check the wiring to your sensors as well they could be corroded.
Old Nov 13, 2014 | 01:39 PM
rmc1148's Avatar
Good advice above.
Old Nov 13, 2014 | 03:50 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
Jak tam....
Could be few things, corroded connector, wiring, gauge cluster, and the last (ecu)....
Old Nov 14, 2014 | 12:23 AM
dominik...'s Avatar
Originally Posted by MadWhip
Jak tam....
Thanks, We will replace cluster gauge, because propably in this car somebody also has some issue during replaced battery some time ago.
Old Jan 9, 2019 | 02:29 PM
eurogarage's Avatar
eurogarage is infamous around these parts
Running into this same problem on a 2002 turbo. Once engine at operating temp oil level failure pops up. DId you have any success with the cluster? I have replace the level and temp sensor for the oil. Oil changed. The pressure sensor is working so I am holding off on replacing it.
Old Jan 14, 2019 | 07:15 AM
techweenie's Avatar
techweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant future
I had this problem on a '02. replaced sender first and it didn't solve the problem. Wiring issue is highly unlikely. Failure turned out to be inside gauge cluster. Good luck.
Old Feb 19, 2019 | 08:31 AM
eurogarage's Avatar
Sent cluster out for repair. Fixed problem!
Old Nov 2, 2022 | 10:38 AM
Ayhan's Avatar
Ayhan is infamous around these parts
Oil level fault
[QUOTE=eurogarage;4767007]Sent cluster out for repair. Fixed problem![/hi who repaired it? I have the same problem thanks
Old Nov 2, 2022 | 10:40 AM
Ayhan's Avatar
Old Nov 2, 2022 | 10:48 AM
602996TT's Avatar
North HollywoodTach Kevin
(818) 761-5137
Old Nov 2, 2022 | 11:48 AM
Ayhan's Avatar
thank you 👍😊
Old Nov 2, 2022 | 12:10 PM
Ayhan's Avatar
thank you very much can you remember the price
Old Nov 2, 2022 | 01:03 PM
602996TT's Avatar
$750 but that was 8 years ago
