Wanted, fuel fitting adapter! Help
Old Nov 30, 2014 | 03:18 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Guys, anyone know where I can get a fitting to go on the barb on the fuel sender for the return line (picture below)
I have a fitting that goes into the return line itself
There are 2 fittings that almost match, the blue one does not quite click on
The Russell one has to be adapted as so which I really dont like
They both need to be adapted to a -6 male
Old Nov 30, 2014 | 04:25 PM
32krazy!'s Avatar
mine was tapped for an-8 bulkhead fittings and an-8 lines ran. can't you adapt a fitting on the return line and use bulkhead fitting?
ID:	408863   Click image for larger version
Old Nov 30, 2014 | 04:32 PM
Thats probably what I will end up doing when we put the bigger turbos on but this is more for customer cars who dont want a non reversible mod, the fittings are so close to fitting I wondered if one was available.
Old Nov 30, 2014 | 06:21 PM
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
Been through this ordeal once, and will not revisit. The stem doesn't protrude enough so I turned your fitting down on the lathe and cut a slot to install spring clip.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
dc3843
Aug 22, 2015 09:33 AM
pwdrhound
Aug 20, 2015 05:54 AM
Phoenix604
Aug 19, 2015 10:39 PM
Nissan GTR
Aug 19, 2015 02:11 PM
