997 SSK install help/question.
Old Dec 13, 2014 | 02:11 PM
khai_tuan_nguyen's Avatar
khai_tuan_nguyen is infamous around these parts
Hi guys (and gals),
I just bought a 997 SSK. I marked the cables before removing. However, when I installed the 997 SSK with the green alignment tool the left cable is off by about 1/4".
Has anyone else experience this issue? Should I go by my marks or the alignment tool?
Any help is appreciated, thanks
Khai
Old Dec 13, 2014 | 04:50 PM
602996TT's Avatar
602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future
I just installed mine a few nights ago you're supposed to use the green tool on the original shifter first Then mark the cables with a marker then remove the unit and install the new one making sure counting the threads exactly as before also using the green alignment tool again then button everything back up.
Btw did you reinstall that small green plate underneath the right side cable that you can see in the picture?
Old Dec 13, 2014 | 05:07 PM
I didn't get that little green plate. I assume it's so the little latch finger doesn't snag on the houseing edge..
Old Dec 13, 2014 | 05:10 PM
602996TT's Avatar
That's what I was thinking I didn't reinstall mine because unfortunately I broke the tab while removing it on the stock shifter. Did you re use yours on the 997 shifter?
Old Dec 13, 2014 | 05:20 PM
I don't get one and didn't have one on the shifter I took out.
Why would you use the green tool on the old shifter AND Mark the cables and then use the tool on the new shifter. Seems redundant.
In my case either my cables have stretched or the previous shifter was installed incorrectly since the marks on the old shifter don't line up on the new shifter with the green tool.
Old Dec 14, 2014 | 09:15 AM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
Try using the white 996 alignment tool, thats what I did. I could not get the green tool to work
Mackchacha
Jul 9, 2019 11:03 AM
PelicanParts.com
997 Vendor Classifieds
Aug 20, 2015 02:39 PM
