Tech Q Massive vibration due to lost cylinder
Old Dec 29, 2014 | 03:49 AM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Just curious here, I just fitted a standalone ecu and we are still getting the coldstart dialed in, it fowled a plug and was on 5, took it for a spin and would not clear, it merely lost a little speed and sounded slightly like a Subaru Imprezza, I replaced the plug and she's fine, we also got the coldstart set up a lot better.
Now we went for a drive with a load of other Porsches and afetr about 30 miles and very bumpy road it went on 5 cylinders again, turns out I hadnt clipped the coilpack connector completely home. Now this time it had an engine vibration from hell, the faulty connector was on the front of the passenger bank (right side looking from back) how can this result in a vibration when the fowled plug (middle plug same bank) merely made it drop power.
Old Dec 29, 2014 | 11:44 AM
Macster's Avatar
My WAG is there is something else going on.
Are there any active/pending diagnostic error codes?
Old Dec 29, 2014 | 04:03 PM
BLKMGK's Avatar
Maybe the plug that was fouled was still getting some combustion?
Old Dec 29, 2014 | 04:12 PM
Nothing else wrong it was just the coilpack connector had come off, took plug out and cleaned it and shes perfect again, just strange how a middle plug virtually didnt effect yet this one gave it a horrible vibration.
Old Dec 30, 2014 | 08:24 AM
Slider's Avatar
I once had a 1971 Monte Carlo (400 hp) and I was on a long trip and I blew a few lifters. The engine felt like it was going to explode. I pulled over and removed the valve covers to select two cylinders equally spaced in the firing order and consolidated my parts to the other 6 cylinders. Once finished, I had a perfectly running 6 cylinder - you couldn't even tell there was anything wrong. Sometimes a imbalance in the wrong place can really be a bad thing.
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
pwdrhound
Sep 13, 2016 10:44 AM
jaehoppa
Oct 22, 2015 09:17 PM
Yellopeter
Cayenne
Oct 9, 2015 11:20 AM
ship it
Sep 7, 2015 10:49 AM
