Winter & Engine Temp
Old Jan 2, 2015 | 03:07 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
My car usually sits on 176 all day long. However, I gave it some beans the other day (empty winter autobahn) in 22 up to 170mph. The engine temp dropped to 115. :-0. I backed off. I guess the sucking of cold air does it but is it safe to drive like this as the dial is actually showing cold engine?
Old Jan 2, 2015 | 04:44 AM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
Dont know if helps or where the temperature sensor is located exactly, but I drove my car in temps like those and speeding the same, but engine temp was the same as usual.
Old Jan 2, 2015 | 06:43 AM
Terminator's Avatar
That's weird? Did you go 170 and above mph? Because up to 120-140 mph my temp was normal too, then all hell broke loose!
Old Jan 2, 2015 | 06:45 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
How long was the car 'up to temp' before you got on it?
Old Jan 2, 2015 | 08:14 AM
Slider's Avatar
I would suspect the thermostat... I don't have much experience with 170+ for any extended periods, but as I understand the theory, the added efficiency of the cooling system with the extra flow you would experience at 170 should cause the thermostat to close to maintain the optimum engine temp.
Old Jan 2, 2015 | 08:22 AM
Dr. Jekyll's Avatar
Dr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of light
+1. My thoughts exactly.
Old Jan 2, 2015 | 09:31 AM
Terminator's Avatar
Properly warmed up. 20 minutes @ 70mph cruising.
Old Jan 2, 2015 | 09:34 AM
Terminator's Avatar
Interesting and plausible answer. But what is the actual temp? And is it safe to drive 180mph in cold weather if the gauge is showing below norm operating temp? What is the actual temp of the engine?
Old Jan 2, 2015 | 09:48 AM
32krazy!'s Avatar
i don't know if its a euro thing but mine runs at 180* F when warmed up. confirmed by my proefi can logger
Old Jan 2, 2015 | 09:56 AM
Terminator's Avatar
I don't think we are on the same page. Mine runs at 176 F all day long in normal conditions. Even when I was at the ring my engine temp was rock solid. Same goes for when I am driving on the autobahn in the summer. The question relates to winter driving at 22 F when at 170 mph I have experienced a very sharp drop in engine temp on the gauge down to 115 F at above mentioned speed.
Old Jan 2, 2015 | 10:34 AM
32krazy!'s Avatar
sorry got the 170 mph and temp * mixed up
Old Jan 2, 2015 | 10:41 AM
BLKMGK's Avatar
Could the pressure from the water pump at that RPM be overwhelming the spring in the thermostat? It shouldn't be dropping temp IMO.
Old Jan 2, 2015 | 11:09 AM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
Sounds like it could be the thermostat stuck in a partial closure - the radiators temp will drop due to speed and the temp would drop within the engine block quickly - the water pump is spinning at 5k rpm so the coolant freely circulates and is dependent on speed. Plausible?
Old Jan 2, 2015 | 11:30 AM
Terminator's Avatar
Plausible. But regardless of the thermostat state, what is happening with the actual engine temp? Is the gauge correct? If so, surely driving flat out at 115 F engine temp isn't good? Ps. When I backed off temp went back to normal within 15 seconds.
Old Jan 2, 2015 | 01:38 PM
Fadi's Avatar
Yes been around 170mph a few times, but after reading your last post something is weird, temperature has a high inertia, not very easy to go up or down in 15 seconds like that..
