Frustration due to my ignorance. Oil drip from oil tank plug.
I thought I was too smart and due to my ignorance, I continued to be troubled and frustrated by a small leak/drip from the oil tank drain plug.
After changing oil, I order the copper oil tank washer and aluminum crankcase washer from pelican. When replacing the oil tank plug washer I noticed its a little smaller and did fit all the way to the plug head, so being so smart I used the larger crankcase washer and then noticed the leak. I looked up the washer in a parts catalog which verified using the smaller washer, so I decided to try it using the smaller washer, it expanded (what it was designed to do) and sealed nicely between the plug and tank. No more drip. I thought I'd share just in case there was another 6speeder trying to out smart what is the right part. Kenny
Draining turbos is silliness
until you decide to change turbos and needto get the torx bolt thats INSIDE the turbo tank and you find out the plug is frozen because its just silly to remove it
no idea what that means. Lol
Got it. That makes sense
