Compression readings
Old Jan 29, 2015 | 08:07 AM
rdprice's Avatar
rdprice is infamous around these parts
Does anyone know what the compression readings should be for a 996TT? (PSI) I've searched and checked the maintenance manual to no avail. Want to know if a car I am considering is good.
Old Jan 29, 2015 | 09:24 AM
32krazy!'s Avatar
Mine were 115 psi minus or plus 1 psi per cyl
Old Jan 29, 2015 | 09:56 AM
johnspeed's Avatar
Nice,,all of them right on with no noticeable variances..
I was expecting as in most engines between 5psi an 10 psi which is still normal for a street motor.
Old Jan 29, 2015 | 10:56 AM
rdprice's Avatar
The video he sent me showed 210 psi.....?????
Old Jan 29, 2015 | 11:29 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
I wouldnt be overly concerned about the actual reading (with in reason) as long at they are balanced. If there's any real concern, leak down test the engine.
Old Jan 29, 2015 | 12:50 PM
rdprice's Avatar
Thanks for the feedback...according to the owner this car was tuned by your shop.
Old Jan 29, 2015 | 07:46 PM
Macster's Avatar
Just a WAG but with the engine's (stock) 9.4:1 compression ratio I'd hazard a guess best would be around 138psi. Actual would be lower not necessarily due to any problems but from less than 100% cylinder filling and with some valve overlap.
Why are you pressure testing the cylinders?
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
longboarder
Sep 12, 2015 12:55 AM
Suds26
Sep 2, 2015 01:33 PM
