K16 Turbo Upgrade
Old Feb 1, 2015 | 03:56 PM
Glasgo's Avatar
Glasgo is infamous around these parts
K16 Turbo Upgrade
Hi all,
I have just acquired a 2003 Turbo w/ Tiptronic transmission. It has ceramic brakes, gemballa tune and exhaust with 100 cell cats. From what I have read, the gemballa package is very conservative. Before this car I had a 2005 Turbo S 6 speed with Giac, Bmc filter and cargraphic exhaust (cat less.) I would like to be at a comparable power rating as this car or possibly quicker (as powerful as the tip can manage) and am considering the 911 tuning Stage 3 package with upgraded intercoolers, K16 turbo upgrade, and catless exhaust. I have written this summary with 3 questions in mind. Is this turbo upgrade equivalent to the stock turbos on my 05 Turbo S? Can the Tip trans handle the load of the stage 3 package? Does anybody on this board have any experience with Any of 911 tuning's products? I am open to hearing other options as well from other vendors you all may have used on this board. I would like to make 550-600whp if possible. Thanks for any help in advance.
Regards,
Chris
Old Feb 1, 2015 | 04:12 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
You're in good hands with marek at 911tuning.
I think you ll be surprised. It seems the k16 billets are a "better" street turbo than k24.
By better I mean you'll notice more of the benefit around town driving. I think you're headed the right direction
I can't comment on the strength of the tippy though.
Old Feb 1, 2015 | 04:15 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
I did built 5 cars in my area running billet K16 with supporting mods .. By 911tuning.com !
You will like them , hit very hard in Low RPM and make good power
Old Feb 1, 2015 | 04:20 PM
Glasgo's Avatar
Thanks for the input guys, I am definitely looking for a turbo that has quick spool up down low versus something that would be more appropriate for a mile long shoot out. I am still interested in hearing any experiences from anybody else that has done a turbo upgrade on a tip.
Old Feb 1, 2015 | 04:25 PM
ysfg35's Avatar
I did it on a Tip , as I recall it made 600awhp running race gas , tip was holding fine , but owner was not push the car hardly everyday !
Old Feb 1, 2015 | 06:37 PM
johnspeed's Avatar
Markski will take care of you and you will be a happy camper.
Old Feb 1, 2015 | 06:48 PM
ramman5600's Avatar
ramman5600 is infamous around these parts
If you hit those awhp goals budget a transmission rebuild into the equation. I'm running k16/16g intercooler upgrade, injectors and tune and Trans is now off getting"built" as it couldn't handle the power long before it started to slip and limp mode. Markski will treat you right. Great tuner and no better customer service.
Old Feb 1, 2015 | 07:06 PM
Glasgo's Avatar
Thanks for your response. It sounds like your mods are very similar to what I have in mind. How much whp are you running currently? I was concerned a tranny build would be necessary. I know somebody with billets who's car wouldn't shift 2-3. Who do you reccomend for the tranny build? I heard a lot of people use protomotive for tip builds. What do I need to budget for, 6-7k? Thanks
Old Feb 1, 2015 | 07:39 PM
ramman5600's Avatar
I'm using rennhaus in FL thru vivid racing . There are a few good builders but do a search and you'll find several options. I don't want to recommend until I get mine back and test it. Budget $8k to cover install and misc unless you're doing it yourself.
Old Feb 3, 2015 | 10:54 AM
SamboTT@ByDesign's Avatar
+1 For Markski's tuning ability and customer service!
Let me know if I can help, especially with parts.
Old Feb 9, 2015 | 10:28 AM
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
You are in good hands 👍🙏
Old Feb 9, 2015 | 11:40 AM
K24 billets we can do as well... 2 compressor wheels available..
you you will be happy either way
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 9, 2015 | 12:00 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
keep the tranny fluid fresh just like any other automatic tranny....
with all the heat you'll end up boiling the tranny fluid....and wear out/burn clutch packs....basically change the fluid every year
hard hitting k16 billets is no problem
Mackchacha
Jul 9, 2019 11:03 AM
vr6tee
Aug 29, 2015 03:52 AM
ECS Tuning - VW
Aug 21, 2015 09:11 AM
Vrseis
Aug 20, 2015 07:41 AM
