Tuned 996tt 1.1 bar consistent, now 0.8 bar?
Old Feb 8, 2015 | 12:39 PM
Lucid Moment's Avatar
Lucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to all
Hey guys, my tuned 996 has been running 1.1bar consistently throughout the powerband. Today I got on ithe throttle and it felt as if there was a lack of throttle or acceleration. Boost shows erratic 0.7 to 0.9bar. No cel. My mods are exhaust, evolution diverter valves, everything else is stock. Can anyone make an educated guess as to what might be going on? No assistant leaks, although I haven't gotten underneath the car yet. Idle is smooth, nothing out of the ordinary. Double checked some vacuum lines, but there is more to look at.
Thanks everyone, for any suggestions.
Old Feb 8, 2015 | 01:00 PM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
That's how mine acted when an intercooler hose was hanging halfway out of the connector. It was a lower hose.
Old Feb 8, 2015 | 01:25 PM
'02996ttx50's Avatar
you're on the right course. +1 vac leak/hose(s). wg's. if the leaks dont become quickly evident you'll have to pressure test,.. and dont forget possibly check valve/wg's that stuff when it goes south wreaks havoc with boost level(s). GL
Old Feb 8, 2015 | 01:34 PM
Thanks guys, the 996 it's still pretty new to me. Must I take the bumper off to check the connections? And get under the car to check the wastegates?
Old Feb 8, 2015 | 01:35 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
Do a pressure test. I use the hoses coming off the turbos, pressurize and you'll find it.
Old Feb 8, 2015 | 05:26 PM
Jacked up the car, took the rear bumper off, realized I didn't need to do this. In the first 2 photos there is an apparent oil leak, which has been there since I purchased the car. Recently changed the oil, nothing out of the ordinary, 8.75 quarts left.
Also did not find any apparent hoses that were not fitted properly. Looks like pressure test is indicated. Remove the hose going into the turbo from the ic, then connect an air compressor? Any advice on the create an effective seal? The only way to do this is with an air compressor?
Thanks everyone.
Lastly what exhaust is this? No markings. I have oem x50 tips.
Old Feb 8, 2015 | 05:57 PM
man, you're good. yes to compressor. i think 911 tuning here sells a tester? or guys make their own from stuff easily gotten from home depot. looks like its something you can also handle. I'm a bit embarrassed to say, i cant recall the exact psi it needs to "hold" but something like 20? my buddy has a kit and compressor, i just stand there opening beer.
but you got this.
Old Feb 8, 2015 | 07:45 PM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Here you go.... Courtesy of Markski
https://www.6speedonline.com/forums/...cs-inside.html
Old Feb 13, 2015 | 06:28 AM
So I did a pressure test, everything is tightened up. Huge difference. Had a leak going into one of the dv's. Had a major leak coming from the ypipe to tb, then another one exiting one of the intercoolers. Unfortunately I did not have another o-ring. I added Teflon underneath the ring, extending the diameter slightly. At this point the pipe didn't quite want to go into the end tank of the ic. Used a little lube and tapped it into place. Another test, airtight Seal!
Major difference driving, I guess I didn't notice it much for a while, as I don't get on the throttle as much.
Thanks everyone.
Old Feb 13, 2015 | 06:46 AM
but you will now it's funny, every time i tighten all connections the car thanks me too. well done.
Old Feb 13, 2015 | 06:56 AM
It was a lie, I try too, but my commute to work is so short, can't have a heavy foot when it's not warmed up. :-)
Old Feb 13, 2015 | 09:17 AM
ha! understood.
Old Feb 13, 2015 | 02:01 PM
Thanks everyone.
9 out of 10 cars have leaks... those who find it are the fee lucky ones...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 13, 2015 | 06:55 PM
Glad there is a happy ending to the story!! Thanks for reporting back, good for future reference for other members.
BlackHorseTurbo
Apr 20, 2016 10:26 PM
markski@markskituning
Aug 24, 2015 10:07 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
