Why all tunes are not the same- logs inside
Old Aug 22, 2015 | 07:13 PM
Hey guys,
I often get clients with cars that are previously flashed with known or unknown tunes, but as usual the cars do not run well. I first walk them thru doing a proper boost test, then fix the leaks, and then re log as usual. Here is a XXX tune log, as you can see the actual lambda bank 1 and 2 are slammed to .73 on boost in third gear.
The next log is with my 1 bar flash nothing else changed. You can see the issue went away and Im even running .1 bar more.
I strongly suggest guys who never logged the car to check actually whats happening to the car on boost... even if you bought a tune yourself. The more educated you are about the tune the healthier and happier you and the P car will be...
best
markski
FOr more info on our porsche 996 turbo tuning please click here
XXX tune 3rd gear pull.
My 1 bar tune nothing else changed.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 24, 2015 | 10:07 AM
rob.boost's Avatar
rob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond repute
It depends on the fuel IMHO. If this is E-85 / E-100 then let it eat (12.0 AFR isn't really that out of the ordinary for great fuel)
Originally Posted by Obb
Looks too lean to me at 11.9-12:1 afr no? Its a boosted motor and 996s from past experience prefer around 11.5:1 afr.
We target .8 to .82 lambda on boost depending on mods / fuel quality etc.
but .73 is def. not right.
Markski
BlackMarketRacing
Dec 8, 2015 01:49 PM
ECS Tuning - VW
Aug 25, 2015 02:54 PM
The Oss
Aug 24, 2015 08:19 PM
magoochi
Aug 23, 2015 05:54 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
