How difficult to remove Exhaust??
I was surpised how easy it actually is to remove the stock exhaust. It took me a little while the first time and it would help to have someone help since its a bit heavy, but it can be done solo. The bumper cover comes off in less than 10 minutes, you need a couple torx drivers and a regular phillips. The Exhaust with the cats have 4 bolts each to the turbos and there is a side bolt for the heat shield, took me about 30 minutes to figure out there were there. and the straps holding the exhaust to the rear, I think it can be done in under an hr once you know everything.
You also have to take off the intake filter to release the O2s from the top, I thought you could remove from the bottom but best to take them out with the entire exhaust when removed.
drinaldis
Sep 28, 2015 01:37 PM
I'mAllIn
Sep 11, 2015 06:38 AM
bmwtmx
Aug 26, 2015 07:26 AM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
