DME Swap and Over Rev
Old Feb 14, 2015 | 08:59 PM
scsponger31's Avatar
scsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to behold
As many of you know I had a DME failure about a year ago. Being my ADD self I never checked the ignition ranges on my original DME prior to the swap. The current DME came from IPGJAMES' car which I know had both more miles and more mods. My question is, whose ignition ranges are on the DME that is in my car?
Old Feb 15, 2015 | 07:13 PM
Macster's Avatar
That's a good question. And I have a good answer. I don't know.
I don't know if the over rev counters are stored in non-volatile memory in the DME or if they are stored in non-volatile memory in an external FLASH memory chip.
A gold level certified senior tech at the local Porsche dealer might know.
Or if you have the DME installed read the overrev counters and see for yourself. I bet you can tell which car the overrevs belong too even if you didn't read the ones from your car's DME before.
Old Feb 16, 2015 | 09:54 AM
ard's Avatar
ard
IIRC, the DME will have the overrevs from IPGJAMES car, up to the day it was removed, added to the overrevs from your car from the day you installed it.
Old Feb 16, 2015 | 10:03 AM
Thank you for all the input!! Looks like I need to find away to pull the data from my original DME.
Old Feb 16, 2015 | 06:25 PM
'02996ttx50's Avatar
that makes sense, you ll have all the operating hours info from the old plus whatever plugged in post install in your own car. weird.
i wouldn't try to put your old data on the current ecu at all. greater possibility of corrupting it. though that's just a stab at the issue. i think you should just keep your new one as is..working fine. keep the old one on hand, and make the old one available at request. it won't be like you're hiding anything, and thats all that matters. someone wants to know what happened before? let em scan it as part of a ppi.
Old Feb 16, 2015 | 06:46 PM
All true! I meant to call GIAC today and see if they can pull the info off of my original DME, but work consumed me haha.
Maybe I should just keep the car forever and ever . If I do, I am wrapping it a different color haha.
Old Feb 17, 2015 | 05:40 AM
re: wrapping! me too! my blk/sliver is Waaayy too played out lol. i feel like the dr suess character. everyone gets stars on thars? i want mine removed
keep it bro!
GT3/GT2/GT Vendor Classifieds
Oct 13, 2015 02:07 PM
tc264
Oct 13, 2015 11:13 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
007 Vantage
Oct 8, 2015 08:35 PM
