IC hose kit
Old Feb 18, 2015 | 08:56 PM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
IC hose kit
Hi guys,
Sambo and I are fixing to upgrade my TT to K16 billets so another 100hp! Replacing clutch as well.
What's a good economical choice for a hose kit as mine are currently stock.
Thanks!
Old Feb 18, 2015 | 09:18 PM
SamboTT@ByDesign's Avatar
I got you Brock. I think the Forge are awesome and you can later remove the couplers to run the hose over the aftermarket inter-coolers pipes for smoother flow.
Old Feb 18, 2015 | 09:24 PM
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
Originally Posted by brockster
Hi guys,
Thanks!
what he said ^
Old Feb 18, 2015 | 09:36 PM
DSCOFF's Avatar
DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !
Go Forge, they're a proven option here
Old Feb 18, 2015 | 10:20 PM
brockster's Avatar
Sweet thanks guys!!
Old Feb 18, 2015 | 10:28 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Was just looking at hoses tonight for a buddy. Forge also seems to be the cheapest. Do the aftermarket ones attach just like the factory ones? The clip?
Old Feb 18, 2015 | 11:09 PM
pwdrhound's Avatar
I used to have the Forge silicone hoses. The ends have to be modified to properly fit the 997.2ICs. I switched to OEM hoses which I've been running for the last 3 years and have over 100 hard track ours on them at 1.3bar without any issues. The OEM hoses are very good. They have a rubber encased composite mesh core. Works good, fits perfect, lasts a long time. I think I paid around $200 for all 4 hoses. No need to reinvent the wheel in my opinion unless you want some fancy colored hoses. What I would do is change out the OEM F-hose. That one is rubber and will split at the seam. I have the Samco hose but Forge among other make good F-hose replacements. Good luck..
Old Feb 19, 2015 | 01:48 AM
Forge are good but also they must fit the ICs, when we make them I always ask what hoses are you using... cant go wrong with forge and even oem as long as the O rings are holding...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
The Oss
Aug 24, 2015 08:19 PM
TrackOne
Aug 20, 2015 12:56 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
