any DIY For engine drop? and how much for labor to drop the motor?
Old Feb 25, 2015 | 05:13 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
Do you guys remember how much you paid to drop the motor? (thinking ahead since i need to fix the coolant leak) I have 3 indy shops on my list, just would like to get rough estimate how much it should cost me to drop the motor and compare the prices. Or I may wait we get nicer weather and do it myself- Glad I found the leak.
Old Feb 25, 2015 | 05:26 AM
'02996ttx50's Avatar
600 = 6 x 100 per hr. or once on a rented lift. 250 for day rental.
Old Feb 25, 2015 | 05:43 AM
MadWhip's Avatar
600 is to drop the motor and another 600 to put the motor back in?
1200 total for that job? 12 hours job?
Old Feb 25, 2015 | 05:45 AM
no, 6 total, but i didn't break it down like that as i had a bunch of stuff done. but 6 in/out is "fair". if you were breaking down the cost for r&r.
Old Feb 25, 2015 | 05:55 AM
MadWhip's Avatar
thanks for quick response -
I dont have a lift so I wont even bother for diy engine drop.
I have to change clutch slave cylinder as well- so it be nice to do it as well.
Old Feb 25, 2015 | 06:52 AM
np..yeah, at the very least, the slave requires you drop it but usually that can be done w just the motor mounts. i wouldn't mess with an engine drop ( again ) independently lol. too much hassle. ( for me )
Old Feb 25, 2015 | 07:50 AM
BLKMGK's Avatar
Is there a DIY thread for dropping the motor anywhere? I've seen a YouTube video but it didn't go over anything but the drop itself and the blocking to support things. Something generally to tell you where all of the connections are to disconnect would be really helpful as I'd imagine slowly lowering an engine and hearing crackling or seeing a wire tugging would really suck. Lift and a hydraulic table (yay HF!) with some blocking seem like the way to go if you've got the space...
Likewise, can't find anything really good for tearing a motor down either
Old Feb 25, 2015 | 08:25 AM
MadWhip's Avatar
lol' i've seen that youtube video about the dude dropping the motor, THAT LOOKS SCARY AS hell! I would rather pay than lowering my expensive motor using 2x4's. and no, you dont want to lower the motor and try to see whats holding it, tons of stuff would get destroyed- connectors, etc...lines....but yeah, IF i would own a lift, I would do it myself. maybe someday I can own one.
Old Feb 25, 2015 | 08:58 AM
Slider's Avatar
There is a DIY on this site. I remember from a while ago - a guy illustrated very nicely how to do it with jack stands. A very nicely detailed write-up.
Old Feb 25, 2015 | 10:21 AM
MadWhip's Avatar
well i got quoted for dropping the motor and put it back in: one place is $1350 another one is $1000 waiting for last indy shop to call me... I need to take care of this crap, I dont want coolant exploding while getting on boost lol.
I'm going to the shop on sat to see where its leaking from.... keep you guys updated. IF the motor will get dropped i think i should pin/weld the coolant hoses.
Old Feb 25, 2015 | 10:32 AM
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
Wow my local indy told me 1600 for engine/trans...
Old Feb 25, 2015 | 11:53 AM
MadWhip's Avatar
and I believe that's what last shop will quote me. I really dont care few hundreds here and there- its nice to actually see whats waiting for me if it comes to worse.
Old Feb 25, 2015 | 12:48 PM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
It is real hard for me to believe that a shop would only charge 6 hours TOTAL to R&R engine and have it back up and running, full of coolant and bled.
Old Feb 25, 2015 | 12:53 PM
that's what I pay. but mitigate that by the fact I'm doing other work, but if one were to isolate and itemize the engine removal and re-install. 6 hours at 100 per hour is what I pay, at the well known and highly reputable shop some of us in SoCal use.
someone else might pay a different price. adding coolant wouldn't be considered a separate line item.
Old Feb 25, 2015 | 04:23 PM
32krazy!'s Avatar
shop manual says 8 hrs labor each way. add the additional cost of fixing the issue. and the cost of all the other things that you should do as long as the driveline is already out.
i mean why put 10+ yr old vacuum lines, coolant lines, crappy oem slave back in? you can do it in your garage if your handy with a wrench
figure 5k$ and you should be good.
