Does the airbag work with race seats?
Old Mar 6, 2015 | 12:58 PM
DaveSen's Avatar
DaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud of
'03 996 Turbo. I've searched a bit but have not found the answer I am looking for, any help appreciated. I am installing aftermarket FIA race seats and 5 point harness with harness bar.
First, wondering if airbags are disabled once the stock seats are removed and the seat electrical disconnected?
If so, any way to enable the airbags, or is this not recommended with race seats?
I already removed the passenger seat and so far it is only a minor annoyance to acknowledge the airbag light at each ignition start.
I noticed more connectors associated with the driver's seat, still working on the seat install, so I have not started the car yet.
Maybe it's no problem, just need to acknowledge the light, and airbags are still active??
Thanks!!
Old Mar 6, 2015 | 03:11 PM
SamboTT@ByDesign's Avatar
You can leave the seat belt buckles in and connected and it will work. Lots of people actually leave then fully installed with the race seats. Then you can still use the factory belts for quick drives. Sometimes it needs a little spacer, depends on seat and bracket.
Old Mar 6, 2015 | 03:33 PM
DaveSen's Avatar
Thanks for the reply Sam, in my case the OEM seats have the 'female' side of the front seat belt integral to the seat. When the seat is removed there is no way to use the original belts.
Old Mar 6, 2015 | 04:01 PM
BLKMGK's Avatar
A resistor could probably be used to fool it, I'd use trial and error or tech specs to arrive at a value though and NOT multimeter on the airbag :-O
Old Mar 6, 2015 | 04:10 PM
Rufian's Avatar
Rufian is infamous around these parts
How about the weight sensing in the seat bottoms, ehh??
Old Mar 6, 2015 | 07:16 PM
32krazy!'s Avatar
you unbolt the seat belt receptacle and fish the electrical harness out of the factory seat. then plug it into the harness on the floor and tie wrap so it stays hooked up. then bolt the seat belt receptacle to the new bases for the racing seats. mine have been this way for 3 yrs
Old Mar 6, 2015 | 07:18 PM
32krazy!'s Avatar
once the seat belt is connected the pass air bag is armed. i believe the sensors in the seat are for disarming the airbag if a child is in the seat
Old Mar 9, 2015 | 09:10 AM
DaveSen's Avatar
Air bag with race seats
Thanks 32Krazy for the info. I replaced the driver seat with a race seat over the weekend, and there were no problems, just have to acknowledge the airbag light which I assume means the airbag is inactive.
After talking to others, I think it is typical to disable the airbags when using harness anyway, so this is no problem for me. I was a bit worried that there would be a seat belt buzzer going off, but it did not.
I'm not sure there is a need for airbags if a harness is used?
The only downside from other posts is that it seems I should have disconnected the battery before unplugging the seat, and since I did not I may need to have a dealer reset when I put the OEM seats back. I will find out this fall.
Old Mar 9, 2015 | 09:32 AM
32krazy!'s Avatar
If you had disconnected the battery there would be no light. Dealer or shop with pwis to turn it off
riozilla
Aug 21, 2015 11:34 PM
TrackOne
Aug 20, 2015 12:56 PM
ppwchiang
Aug 20, 2015 10:28 AM
pwdrhound
Aug 20, 2015 05:54 AM
Walorus
Aug 18, 2015 01:39 PM
