Help Please,,Cold Start Up Problem
Old Apr 6, 2015 | 08:16 AM
  #46
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Originally Posted by johnspeed
Thanks.. Question though , wouldn't it be worse then if it was rich when its warmer and not an overnight cold start?
Its only trips the cells and memo message when its cold out,,30s and under.Thats when its idles the worse ..If it was rich that would help that cold start better?
So do you still think , since I explained it better in the above post that it still could be the Temp Sending sensor..
Thank again..
I am pretty sure there is a initial startup map that handles fueling only for the first minute or so . Now if your sensor is reading it is 50 degrees and it is actually 30 u will be lean if it is actually 70 degrees you will be rich but it becomes easier to start the warmer it is. So yes i yhink it could be a fsulty temp sensor but it is easy enough to check as long as you log it on startup and see how close it is reading to ambient. I wouldnt go changing it out unless i logged it first.
Old Apr 13, 2015 | 03:14 PM
  #47
johnspeed's Avatar
Hi,Took a break for a while because
Flew down to Arizona with my 16 yr old daughter to get her first car and drove back on Rt.66 to Chicago.
Ok is it an easy job to get to Temp sensor, ,I think I will try that .I am at almost 50k miles.
Old Apr 14, 2015 | 05:03 AM
  #48
'02996ttx50's Avatar
gettin your kicks on route 66! retirement is such a drag
Old Apr 19, 2015 | 03:11 PM
  #49
johnspeed's Avatar
HI,,So does anyone know where the coolant temp sensor sending unit is?
Old Apr 19, 2015 | 08:28 PM
  #50
joetwint's Avatar
look behind the belt tensioner it is located in a water manifold/bracket that the tensioner is bolted to
Old Apr 20, 2015 | 05:40 PM
  #51
johnspeed's Avatar
Thank You.
Old Apr 20, 2015 | 07:16 PM
  #52
joetwint's Avatar
Thank You.
you will need to remove the y pipe and alternator and it is just behind alternator.Read this thread it will make it more clear
http://www.renntech.org/forums/topic...ensor-install/
Old Nov 24, 2015 | 04:51 PM
  #53
johnspeed's Avatar
HI Guys, Well I needed a new alternator in summer as the dealer said, extended warranty picked it up.
So I had them replace the coolant temp sensor then because it was easier now.. But they still charged me a pretty penny for antifreeze flush and swap .
Ok ,, Its been a few times with the high 20s low 30s temps outside here at night.
No more cold start up issue,,,,hopefully it is took care of it.. Only problem now is my extended warranty ends at the of the month . Can not get another one due to age,, not mileage reason.
THANK YOU to all that gave me feedback and help .
Old Nov 24, 2015 | 05:07 PM
  #54
how is the start up now that its cold...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 24, 2015 | 05:36 PM
  #55
johnspeed's Avatar
Hi Mark ,, As I said above no problems,, yet .LOL.
I do have that new F pipe, one day when you can . Thanks
ritchrwi
Aug 29, 2015 08:27 PM
gulf gt
Aug 27, 2015 10:27 AM
magoochi
Aug 23, 2015 05:54 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
