Toyo R888 problems?
Old Mar 19, 2015 | 01:11 PM
  #61
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
Originally Posted by 996tt550hp
You are correct. I have never had a slipping clutch issue before so this is the first time I experienced it. Man I have to say it sucks lol.
Oh I know the feeling. My stock clutch lasted a good 10,000 miles on my 700+hp... But then it was toast after a launch from a dig vs a gtr- WHOOPS!
These cars have so much weight on the back tires. Launching is rough.
It started slipping on WOT from 5k all the way to 7- and I knew it was donezo.
The funny part is, my shop said the stock clutch looks like it was "driven softly". Its funny because I slam gears hard all day every day. I guess it pays off to rev-match every shift?
Old Mar 19, 2015 | 05:38 PM
  #62
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
Have my R888s on 32.5/36 PSI after running hot for 30 miles and they seem to be okay there but with my 235/40 and 315/30 I have to drive with PSM off always when I thrash her otherwise the PSM just locks everything up. Used to keep PSM on in colder temps with my Potenzas.
Drove today in 30F temps and the tires were awful
Old Mar 20, 2015 | 11:12 PM
  #63
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
I have no psm problems. Just the squirreliness. And it doesn't see to be improving.
I may have to take it in somewhere.
Old Mar 21, 2015 | 08:44 AM
  #64
stilov's Avatar
Ok I just pulled the drive shaft again, so now I'm rwd.
The two changes to the car I made right before I noticed this were
Replacing cord showing 335 to 315 AND
Putting my driveshaft back in.
So if I still have the squirreliness, it has to be the newer rear tires.
If it goes away, it's something with the awd drive and slightly taller tires in front.
Old Mar 21, 2015 | 01:21 PM
  #65
stilov's Avatar
Still has the sway feeling
So maybe tires. Anyone have any recommendations on suspension parts to look at?
I just want to narrow it down before I take it in.
Old Mar 21, 2015 | 01:33 PM
  #66
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
Stilov, are you in Houston this weekend? If so, IM me.
Old Mar 21, 2015 | 02:35 PM
  #67
'02996ttx50's Avatar
"maybe"?! those tp's seemed whacked but you know best but..geez bro..get rid of em! lol.
Old Mar 21, 2015 | 02:59 PM
  #68
stilov's Avatar
I'm not in Houston.
What do you mean tp's? Tire pressures? I have run it all at this point with no real identifiable improvement.
I have varied the pressures by nearly 13 psi at 2 psi increments and nothing seems to affect it.
Old Mar 21, 2015 | 03:31 PM
  #69
thats why ultimately i would suggest you bail on the toyos. i doubt its the suspension components? you know a lot about your car, i would go with replacing the tires. i have never in all my 911 days found less expensive tires to be a viable option, but certainly understand the reason "we" try anyway.
Old Mar 21, 2015 | 04:25 PM
  #70
Whereitsat's Avatar
I don't use Toyos for price. I use them for traction. The Nito's and PS2's just don't grab. I'd love to try the SuperSports, if they came in the correct 18" sizes. PaulieWalnuts has good luck with them in 19's.
Old Mar 21, 2015 | 04:26 PM
  #71
stilov's Avatar
I had no complaints on the first set. Except they wear out fast.
Old Mar 21, 2015 | 08:33 PM
  #72
i only wish i could get the pss in 315/30. cheap tires are shyte on these cars, is what i think.
but hey if the first set worked fine, then of course, its something different. but what if not something causing your alignment to be whacked? or the tires being mismatched frt/rear..? then.. what?
as to grabbing whereitsat? I've never tried toyos so i cant speak on them per se? but I've always had more than enough grab with ps2's but now rwd i like to throttle steer any chance i get. ps 2's wear way too fast for the $500+ per copy.
the p zeros are like very hard glue. I've just scrubbed the rears and am going to back off some tp. too tight a ride.. but tough as nails.
all of this is different for each of us,.. as we are. lol
Old Mar 21, 2015 | 08:47 PM
  #73
stilov's Avatar
I've had my alignment done. They said it was barely out from before. No difference.
I thought about the slightly taller front v rear and awd drive, so I pulled the driveshaft today. No difference, never had any psm lights or trouble.
A buddy is going to let me drive on his spare set of tires.
Calling the toyos cheap isn't quite true. They are track tires. They don't last long. They are sticky. Whereitsat and I have very similar setups and I made 690 rwd. Obviously stickier they are, they faster they wear.
I've thought about michelins which is gladly do in awd configuration if it's a tire issue. If not, these toyo have a good amount of wear left.
Old Mar 22, 2015 | 08:12 AM
  #74
i only run n rated tires rwd and approx 550+ rwhp and have only had issues with tires when they were not n rated so i stay with michi or p zeros. was just trying to help. good luck with em.
Old Mar 22, 2015 | 08:33 AM
  #75
stilov's Avatar
Sorry I didn't mean that I don't appreciate the advice.
I understand the benefit of n rated and when speaking about street tires I see it as a completely valid point.
However, all the guys that race on the track don't use the n spec.
I know there are trade offs. But I was running r888 prior to the problem.
It's the newly developed symptom that troubles me.
