Tire size change! Why did i not do this earlier?!
Old Apr 10, 2015 | 11:52 AM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
Just mounted my PSS 305/30/19s. I used to run 315/25/19 PS2s. The PSS are wider and the sidewalks look so much better on my wheels. Name:  image-3989002484.jpg
Size:  507.3 KB Mounted Name:  image-3808528701.jpg
Size:  423.0 KB Widths - 305 left/315 right
Old Apr 10, 2015 | 01:51 PM
moacur's Avatar
moacur has a reputation beyond reputemoacur has a reputation beyond reputemoacur has a reputation beyond reputemoacur has a reputation beyond reputemoacur has a reputation beyond reputemoacur has a reputation beyond reputemoacur has a reputation beyond reputemoacur has a reputation beyond reputemoacur has a reputation beyond reputemoacur has a reputation beyond reputemoacur has a reputation beyond repute
Looks great! Bet they look even better on the car. Let's see some pics
Old Apr 10, 2015 | 01:57 PM
Steve B.'s Avatar
Steve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to behold
Is that the 305 on the left and 315 on the right? Wow... what a difference! I hear PSS are a better tire. Guy I know has a R8 V10 and said that the PSS are cheaper and last longer than the PS2.
Old Apr 10, 2015 | 01:58 PM
brockster's Avatar
Thanks! Will do when I get it back on the ground. Clutch, ICs, and SAMs billet K16s going on now! I'm gonna do a DIY on turbo and ICs.
Old Apr 10, 2015 | 01:59 PM
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
Look good. What size fronts match these rears for AWD ? I believe you need to run a correct ratio between fronts and back on awd.
Old Apr 10, 2015 | 02:02 PM
brockster's Avatar
Steve - that's it exactly. Going to track 21st will post my thoughts afterward!
Old Apr 10, 2015 | 02:05 PM
brockster's Avatar
245/35/19 on fronts
Old Apr 10, 2015 | 09:00 PM
Steve B.'s Avatar
I can't believe how much wider the 305s look over the 315s. Is it the section width of the tire that makes such a difference? Got any pics of the rear of the car that would show how wide they look? Is it noticeable to your eye?
Old Apr 10, 2015 | 09:05 PM
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
Nice! No rubbing whatsoever? Would you happen to have a profile shot of the car with the new tires on? Wondering how 'beefy' the tires look.
Old Apr 10, 2015 | 09:37 PM
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
I'm lost, I admit it. This is just a perspective thing from the camera angle, right? Otherwise, how can the 305s look so much wider than the 315s?
-V
Old Apr 10, 2015 | 10:43 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
Dude can you send me a picture of your ride height?
I'm running 19x12 on the same 305/30/19 PSS as well and I just got the car back today from my coilover install. They put the car at GT2 ride height and alignment and the car is barely driveable it rubs so much. Rubs like crazy on compression on the inner and is also rubbing on the outside.
And this is after I did GT2 fender liner brackets to get more clearance and rolled the fenders.
Old Apr 11, 2015 | 12:35 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
My 315s did that. Went to 305 and was perfect. What's your camber and toe?
Old Apr 11, 2015 | 09:51 AM
The Pork Hunt's Avatar
The Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond repute
Doesn't make sense to me how a 305 could be that much wider than a 315 tire?
Old Apr 11, 2015 | 10:37 AM
rmc1148's Avatar
Agree the tire width comparison does seem off/odd?
Old Apr 11, 2015 | 10:48 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
I have the same tires on my car and love them.
A couple things make the comparison picture look deceiving.
1) The 315 is completely worn on the inside edge which makes the tread look like it start farther in.
2) MPSS's have a super meaty rim protector which makes the entire tire wider compared to others. If laid on the side the tread part will be offset compared to other tires.
