Need Help with stripped wheel lock bolt removal!
Old Apr 11, 2015 | 08:06 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
Originally Posted by ASLAN
I saw that, but looks like it's for nuts and bolt heads, not bare studs.
It will work on the stud. The way it works is it you pound it on the offending fastener and it has teeth that dig in more the more you try to loosen it. If it slips that just means you need to pound it on harder for the initial bite or you have the wrong size.
Old Apr 11, 2015 | 11:09 AM
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
You have threaded portion sticking out --- Screw an acorn nut onto the threaded part that is projecting out enough to bottom it out onto the lock nut flange but not so much that it tightens the stud more. !!!!!! But before you do apply a bunch of red loctite to the threads. Let the loctite set up 100% completely then remove the stud with just a regular socket.
Old Apr 11, 2015 | 11:27 AM
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
I've personally helped a friend in the same situation by tig welding a nut onto the bolt. Easy peasy 10 minutes with no damage to the wheel. Though of course it requires a welder.
You might want to go to a wheel/tire shop. They deal with this stuff all the time. They typically will just hammer in a throwaway socket.
If you have patience, and some throwaway bits, you could drill out that bolt.
Old Apr 11, 2015 | 01:59 PM
sinKing's Avatar
Some of you really make this way more complicated than it needs to be.
Old Apr 11, 2015 | 02:02 PM
'02996ttx50's Avatar
i'm with the hammer on it advice too lol."we" drilled/hammered etc until the sucker came right out.
Old Apr 11, 2015 | 10:30 PM
Engine Guy's Avatar
True that, how could it get any easier then my solution, A $2 nut from any auto store and buy a tiny sample sized bottle of loctite if you already dont have any. No tools to buy, no drilling, no welding... It's just so simple.
And then if my method fails you have every other more destructive method of removal including all the easy outs or welding.
Old Apr 19, 2015 | 12:20 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Update:
Thanks to SinKing and Engine Guy! I could not find an acorn nut the right size, but SinKing's nut removal kit suggestion worked like a charm. Stud was out in 2 minutes!!! Rep points to you both!
Old Apr 19, 2015 | 06:16 AM
sinKing's Avatar
Glad it worked out for you. I picked up that kit about 10 years ago and it has been WELL worth the initial purchase price.
Old Apr 19, 2015 | 06:27 AM
rmc1148's Avatar
I have bought similar tools in past that did nothing but I'm going to buy this since it seems to work and hey cheap lol. Thanks sinKing!
no1joey
Sep 2, 2015 12:32 AM
Sep 1, 2015 03:16 PM
Lucid Moment
Aug 20, 2015 02:22 PM
cab83_750
Aug 19, 2015 12:37 PM
