Valentine One Question (and EZ PASS )
Shank, there are 2 places where there is no coating on the windshield. You can see it if you look at it just right.
1. Just to the right and left of the rear view mirror, there is about 2-3 inches of clear area for the I-pass.
2. In between the speedo hump and the I-drive hump, 1 inch above the base of the dash, there is approximately 4" x 8" trapeziodal clear area. If you place the V1 1 inch above the dash, and right in between both humps, you will be spot on and it will work perfectly. Then route the straight wire to the passenger side, through the glovebox and plug it into the passenger footwell 12v outlet. Works perfectly.
turbotuner20v
Sep 11, 2015 12:02 PM
hacellular
Aug 31, 2015 08:34 AM
carrera4slakem
Aug 20, 2015 11:36 PM
