Got Windows Tinted, now interior lights won't turn off….
Old May 5, 2015 | 07:39 PM
dc3843's Avatar
dc3843 is a jewel in the roughdc3843 is a jewel in the roughdc3843 is a jewel in the roughdc3843 is a jewel in the rough
ALL:
I got my windows re-tinted today, and when I picked the car up from the tint shop, when I close the doors, the lights NEVER turn off. When I get out of the car, the lights stay on, I try and lock the doors and the car immediately honks but doesn't lock the door. when I lock the door manually it locks, but honks and the lights stay on. I hooked up my durametric and I'm getting a current code of 46-control locking synchronization, and I get other codes 54, 33, 49 and 60…. What could the issue be?
Old May 6, 2015 | 08:59 AM
dkfx's Avatar
dkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond repute
is the switch below the mirror pressed all the way to the left to make them stay on? I know the car will honk if you try to lock it and the door is open. may be simple, not not.
Old May 6, 2015 | 09:33 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Is your glove compartment fully closed?
Old May 6, 2015 | 12:10 PM
dkfx's Avatar
^^ damn 2002+ elitists... lol
Old May 6, 2015 | 01:15 PM
cab83_750's Avatar
Hahaha
I have never owned a 996. Does the 996's horn honk when something is ajar while activating the alarm?
Old May 6, 2015 | 02:09 PM
'02996ttx50's Avatar
yeah, it'll beep when either the glovebox or center console or any compartment isn't fully closed upon locking with remote. also you can disable the i/r inside cabin motion sensor by double clicking the remote quickly upon looking which'll produce the same fast beep. that lets you know you've disabled it. it also puts the car to "sleep" instantly.
Old May 6, 2015 | 02:20 PM
cab83_750's Avatar
So, assuming that OP's issue is an open glove compartment or center console, I wonder why installer had to go thru his compartments??? Jk!
Old May 6, 2015 | 02:21 PM
cab83_750's Avatar
Op,
Any updates?
Old May 6, 2015 | 02:28 PM
presumably for the same reasons as valets often do. in other peoples cars ! hah
Old May 6, 2015 | 03:12 PM
cab83_750's Avatar
We should probably quit before OP starts freaking out about missing items and before he starts thinking about ferris-bueller parking lot ride. Haha
Old May 6, 2015 | 04:03 PM
BLKMGK's Avatar
He had tint done, they probably removed his door panels. What might they have jacked up that would cause this? I don't recall seeing a door pin to detect closure so there must be something inside that checks this and would explain why it won't set the lock or turn off the lights...
Old May 7, 2015 | 05:03 AM
good point, but no tint I've ever known of messes with the door latch mechanisms, but they could've messed with the window regs. i do know if they aren't adjusted properly, they will disallow the film to be placed properly as it affects the end position of the glass ( obviously ).
but the beeping unless something is indeed faulty? means a compartment is not fully latched is all.
Old May 7, 2015 | 06:59 AM
BLKMGK's Avatar
Worked before tint, doesn't work after. Simplist explanation is that something was done during the process and since they pull door panels to do tint properly that's where I'd be looking. Interior lights won't turn off and alarm thinks door is open - my troubleshooting tree says something inside the door that makes the light come on is dorked :P
Old May 8, 2015 | 08:19 PM
dc3843's Avatar
Turned out to be the door lock mechanism. The tool they used to pin the door to keep the window all the way up broke a lever and it made the car think a door was open. Fixed.
COBB Tuning
Jan 1, 2025 09:02 AM
Apex Chase
Mar 28, 2016 02:00 PM
alevine
Nov 4, 2015 10:05 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
gulf gt
Aug 27, 2015 10:27 AM
