bad motor mounts?
Old May 14, 2015 | 12:46 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
bad motor mounts?
For those that have hand bad motor mounts, what did it feel like handling wise before you fixed the problem?
Old May 14, 2015 | 01:42 PM
'02996ttx50's Avatar
you'll feel it. ever so slight *slop*, esp on lateral ( side to side ) accel while and during shifting.
Old May 21, 2015 | 09:01 AM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
^^ throttle response is much quicker with new mounts. If you are replacing with semi-solid , they will transmit more noise into cabin. Big difference between OEM and semi-solid. I would have liked to try brand new OEM motor mounts to see what car would be like with all I've done vs the semi solid that I went to .
Every "performance" mod I've done added more cabin noise, first it was exhaust, then turbos, then LWFW/clutch , motor mounts, and now coil overs.
There are days that I miss the touring plush ride of my turbo
Old May 21, 2015 | 11:48 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
I changed my mounts and put the wevos in. The stock ones were still ok but cheesy. I could push the steal thingy sideways.
The wevos are great. A little more engine sound inside, but thats fine.
Old May 21, 2015 | 01:38 PM
agree with both above posts on all counts.
we be running wevos too. vastly improved and yes, sounds AND feels like it lol
Old May 21, 2015 | 02:09 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
offtopic : is it hard to replace engine mounts?
Old May 21, 2015 | 02:18 PM
no. 15 mins per side.
Old May 21, 2015 | 02:38 PM
MadWhip's Avatar
that's my next mod, motor mounts and suspension, i'm sure after 10 years+ it starts growing mushrooms in there.
Old May 21, 2015 | 04:39 PM
32krazy!'s Avatar
support the trans and drop the trans mount and check it. if it shows any signs of cracking in the rubber bushing go to home depot and get a tube of window weld. fill the entire rubber area with the window weld and let it cure for 24 hrs. same as the 200$ mounts for 20$
Old May 21, 2015 | 04:54 PM
^^ yeah, only to add that any car that likes to be "pushed" is gonna have all the rubber bits crumbling after 10+ years if they are original. t-mount, mm's, all of em
Rguy
Apr 12, 2020 11:11 PM
jaehoppa
Oct 22, 2015 09:17 PM
