Oil Change Fail - Overfill
Old Jun 11, 2015 | 05:11 AM
  #31
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
At this point I would flat bed it to the dealer. No offense but he sounds like a novice DYI'er and I would hate for him to attempt any troubleshooting going forward as he might do more harm then good. Good luck!
Old Jun 12, 2015 | 07:17 AM
  #32
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
I dont train turbos' i put 7qts fist, even if its half way less, so what, i let the car warm up, go around the block. pull in, check. add. I always leave one or two bars from the top showing empty--- better than overfill.
IF i were you i would probably drain some oil. also check your lower intercooler pipes from turbos, you probably have
some oil there just chilling.
I have no idea> how people even change sparkplugs with the bumper on---- you have sparkplug sheilds, etc. removing real bumper is easy, just few screws here and there.
like people posted above, always check, read, study, before you attempt anything.
We have plenty of articles.DIY'S here floating around and tons of friendly people that can help you.
Old Jun 12, 2015 | 07:24 AM
  #33
MadWhip's Avatar
Originally Posted by thekvltisreal
thanks for the input guys.
to correct: didn't run on no oil to temp
also
i didn't drain the oil pan the second time, just the crankcase and reservoir
after reading , what?!?
see this picture: -thats where drains are
Old Jun 12, 2015 | 08:15 AM
  #34
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
Gold Standard Whey FTW
Old Jun 12, 2015 | 10:33 AM
  #35
levinsje's Avatar
levinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to behold
After seeing the 997 engine in parts I first drain the used oil, measure the amount of oil in the drain pan by filling up old gallon plastic water containers that I use for disposal, and put in the same amount of fresh oil back in minus 1/2 a quart.
The Porsche mechanic at the dealer really proved his point after showing me that engine!
Old Jun 12, 2015 | 12:11 PM
  #36
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Originally Posted by YJosephTT
wow that oil is really black, what color is your oil usually after you drain.
Last oil change I did it was dark but not black like your video....
Might be a trick of the light, that was the new oil the guys tech had put in !!!!
Old Jun 12, 2015 | 12:15 PM
  #37
Originally Posted by rxbike
What he really should do is pull IC, hoses, intake plenum apart, see if there is oil in there. If that is really the case, clean them all out, hand crank the motor over to make sure it hasn't seized. Pull a plug to see if there is oil there, if so pull all of them, clean the area really well, put new plugs in, reassemble everything, ADD OIL (not too much ) and pray that motor starts and run. Excess in exhaust will burn off !
We have had several in like this and after a good clean they have all been fine, one guy even drove 60 miles to us with it overfilled the same.
Old Jun 12, 2015 | 03:52 PM
  #38
BLKMGK's Avatar
Left arrow crankcase, right arrow the dry sump oil tank - brace the drain bolt with a wrench or you risk trashing the tank (24mm?). To the far right and not highlighted you can see the passenger side turbo reservoir, there's one on the driver's side too. I drained all of the above for mine.
Old Jun 15, 2015 | 11:34 AM
  #39
MadWhip's Avatar
BLKMGK - that is true, on the sump oil tank you need to use 2 wrenches, otherwise you may trash that oil tank , and it might snap, depends how tight the bolt sits ! always use one hand to hold the wrench and use the other hand to unscrew the bolt.
Old Jun 15, 2015 | 11:42 AM
  #40
rmc1148's Avatar
You would think they would have braced the tank better= is an accident waiting to happen if you don't use two wrenches.
Old Jun 15, 2015 | 04:47 PM
  #41
BLKMGK's Avatar
It's sheet metal and the tutorial I read before changing mine cautioned me to do this and when I got under there I could understand why! I had to use an adjustable wrench it was so big but I kept the drain bolt from twisting anything.
Old Jun 15, 2015 | 07:59 PM
  #42
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
An experienced tech would recognize this immediately. And Porsche dry sump tanks have been around since 1963.
It is not a Daihatsu. DIYers coming from that level vehicle and the average Jiffy Lube tech are out of their league. Not accepting this is an accident waiting to happen.
Old Jun 15, 2015 | 08:06 PM
  #43
rmc1148's Avatar
Its an accident waiting to happen if you DONT USE TWO WRENCHES that is a fact.
Old Jun 16, 2015 | 08:48 AM
  #44
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
I agree, let someone who knows these cars get it back to 'correct', then (with all due respect) reconsider doing more DIY'ing or not.
Old Jun 16, 2015 | 10:35 AM
  #45
rmc1148's Avatar
Sadly I agree with above comments, doesn't sound like doing your own maintenance is a good idea.
