Fuel Rail Connector Sizes
Hi,
Can someone please clarify what connector type and sizing the male fitments are on the fuel rails? As attached and circled from the main feed fuel line?
Regards
Regards
Yeah i can find an-10 male to m16 x 1.5 male but not an-10 male to m16 x 1.5 female, so think i will have to get m16 x 1.5 female to female, then use the an-10 male to m16 x 1.5 male
Hi johnny, do you know if the fuel return fitting is also m16 x.5? The one located below the plenum/throttlebody after the fuel cooler?
UK cars don't have fuel coolers, I have only ever seen one so I cant answer that i'm afraid.
Hi, ok thanks, i can see the return near the fuel regulator but cant trace it further than this, i can see a connector under the plenum/tb which runs near where the old stock filter use to run and then under the coolant tank and to the front, so im thinking this could be the return but hard to see at the moment with the engine back in the car
OK dude Ill try talk you thru it, on your RHD car the fuel goes in the Passenger rail at the rear of the car, it goes forward along the rail and exits at the front on the inside of the rail where it crosses to the back of the drivers side rail on the inside and goes forward to the reg end where it exits the the drivers rail and comes back across to the passenger side, the return is easy to spot as its a black plastic pipe with a push fit end.
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
turbotuner20v
Sep 11, 2015 12:02 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
