Wheel Recommendations for 9 X 18 and 12 X 18
i hate the bother of selling sh*t lol. hate to haggle or dicker though I'm not bad at it. i guess i'll keep the oem sway in case i snap another gt3 bar!!
I love these wheels...https://www.6speedonline.com/forums/...s-996-gt2.html
However, now that I am running bronze...I find the "silver" a bit dull, nothing a powder coat couldn't tackle.
I run the CCW C14s in that size 9" 12" John had them shot peened for extra strength for the track, I also run them in a 11" F 13" R on my race car same wheel and shot peened surface running full Pirelli slicks, never a problem. The service from them is top notch, and for what they are a great price.
Couple of year ago I switched to Finspeed forged wheels with their beed knurl option which totally eliminates the problem by locking the tire bead to the wheel. This is the same technology that us used on the OEM Nissan GTR wheels and it works like a charm. The Finspeeds are amazingly light, strong, and built to your specs. Price is comparable to CCW, maybe $700-$1000 more depending on options of which there are plenty. I have several sets and they are the best wheels I've ever owned. Below are Finspeed F11s in Magnesium 18x9ET47 and 18x12ET40. Something to consider...
[url=https://flic.kr/p/vff8A1]
I have a perfect set of GMG World Challenge wheels I'll be happy to sell you, from my GT2. They are 18 X 9 and 18 X 12. I have a couple threads floating around here about them, with pictures. They are in perfect condition. I hardly drove them at all, and never on the track.
Forgestars do require hub rings, but we provide free rings with all our orders that need them!
The CF5 and F14s are both available in 18x9/12 in GT2 fitment, and pricing is under $1450 for a set with a custom color of your choice!
I'll send you a PM with some more info!
Man I want to get rid of my 19s
Pm me with a price.
I've been through tons of wheels and all have been tracked heavily. I have also had 4 different set of 18x9x12 CCWs and sold numerous other to customers. They are excellent wheels (and John at CCW is a great guy with superb service) but come with one minor drawback that you want to keep in mind when used on a high torque car. It is very difficult to keep tires from not moving on the rim if you track your car with sticky R- compound tires. More of an annoyance than anything else. Every set I've had, whether powder coated, anodized and shot peened have resulted in tires constantly creeping around the rim under hard braking and hard acceleration with sticky tires (usually about 2" or so per session). I have dry mounted them, scuffed up the wheel beed with 40 grit paper, used hair spray, and even resorted to 3M spray adhesive. Using 3M has helped but they still moved a little eventually throwing the wheel assembly out of balance. Any type of vibration drives me crazy but may not be a big deal to others. I would end up having to flip the wheel left to right every 4 session or so to creep them back in balance. A friend of mine with CCWs on his 7GT3 ended up painting the wheel bead with paint that had fine grit sand mixed and and that did the trick for him but cost him a few hundred to get it done. This is a common problem that many guys have had if you do a search on Rennlist.
Pwdrhound , thank you for the advice. I have heard of the is issue with the tires moving on the wheels.
Put your 19"s up for sale and your Forgestars should be ready by the time you get them sold
No worries my friend. Just trying to same you some aggravation. That was actually my reason from moving away from CCWs. Just got fed up with having to flip the wheels on the car to keep things in balance. It's a distant memory now...
the problem with em buddy, and i mean PROBLEM is that silly ring. others will tell you its fine no issues yadda yadda. truth is, they aren't made for the car in 18 so ya need that stupid ring in the center of the hub. couple that with a different machined bore for the lug holes ( conical! and believe me NOT COMICAL ) and you're into what caused me nearly 3+ years of continuing frustration. now, if you just TOOL around? then sure ok, may be fine. but if you PUSH the car and the lugs aren't PERFECTLY suited and the right temperance for undue stressors e.g. lots of lateral stress? then you might well experience what i did. issues galore. I'm sure 19's are just dandy but i will never again run 19's owing to where and how i drive.
the OZ allegerita is quite the opposite and i can highly recommend them in a perfect gt2 fitment, all while accepting oem LUGS DUH..
lol
lolWhat is this ring you speak of? I've never heard of that
