Weighed the car this afternoon
Old Aug 2, 2015 | 08:00 AM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
pwdrhound's car such a dream car.
I'm currently 3120lbs with 1/4 fuel here. Lots of heavy parts but also have done few very important lightweight parts as seen from the figure.
For pwdrhound I suggest radio delete with empty OEM speaker grilles and storage shelf instead of the headunit for a clean OEM look. Also would install the Clubsport cage, you get a much safer clean full cage (not the most safest though but it was FIA-specced back in the time) which is also quite lightweight and period correct for our cars!
Also, the problem with seat weight with the OEM GT3 seats are the HEAVY seat brackets....they weight a ton. Haven't done anything for those though.
And, if going with carbon doors (check Cargraphic with crash impact bars) and lightweight door panels you could still remove a lot of weight. Perhaps 70lbs or so. But a bit expensive project for my liking. Also lithium batteries are much less than that 21lbs.
Keep up the good work!
Old Aug 2, 2015 | 08:10 AM
32krazy!'s Avatar
couple of things i can add here. i have the voltphreaks vp900 lithium battery. 7 lbs!!! also gmg racing has a new seat base that sits lower and is lighter than any of the current bases on the market save the recaro fixed seat rails
Old Aug 2, 2015 | 08:30 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
Originally Posted by 32krazy!
theres no airbags but there are weight sensors. you have to retain those or you get a dash light that the dealer has to turn off
I don't think I unplugged my battery any time I swapped my seats. I'm still running those Momo's I bought from you. No airbag light.
Old Aug 2, 2015 | 10:15 AM
32krazy!'s Avatar
got to unplug it.
Old Aug 2, 2015 | 11:29 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
do not have to unhook the battery, just do not turn on the key/ignition.
Old Aug 2, 2015 | 12:13 PM
32krazy!'s Avatar
when dealing with electronics its always best to unplug the battery and wait 10 minutes or so. then you never have to worry about someone else turning the key or you forgetting your not supposed to. its backyard diy 101
Old Aug 2, 2015 | 12:54 PM
rmc1148's Avatar
^Very good point, nothing worse than an electrical problem in my opinion.
Old Aug 2, 2015 | 01:00 PM
993GT's Avatar
I agree in an unsecure environment disconnecting the battery makes sense, also for jobs involving large current or self-danger...starter, alternator...belt replacement, etc.
For the seat swap there is very low risk, and if you 'mess-up' then reset with Durametic or other favourite reset method...just stating fact that battery does not need disconnected.
Old Aug 3, 2015 | 08:50 AM
b4stiTTS's Avatar
b4stiTTS has a spectacular aura aboutb4stiTTS has a spectacular aura about
Interesting in case of the base Frame for the seat, any pics/ links/ threads?
Old Aug 3, 2015 | 09:15 AM
32krazy!'s Avatar
gmg racing has them on their website
Old Aug 4, 2015 | 11:53 AM
b4stiTTS's Avatar
Didn't find them but will check again
Old Aug 4, 2015 | 01:09 PM
32krazy!'s Avatar
http://www.gmgracing.com/store/2004/...6-997-991.html
Old Aug 6, 2015 | 10:04 AM
b4stiTTS's Avatar
n1 Piece, thank you!
PorscheEnthusiast
Nov 13, 2015 02:23 PM
DSCOFF
Aug 23, 2015 01:22 PM
pwdrhound
Aug 20, 2015 05:54 AM
