Clutch 996 turbo
I did the clutch my self, but my transmission went off for a rebuild, and fitment of os giken LSD, so im not sure if they would have removed the spline axle cover or not?? But i will for sure be adding some loctite to those buggers when i put them back in.
i would be a bit worried about compromising the pressure plate. thats a lot of metal that was removed and they are under tremendous pressure. for me i would have to replace it and have the peace of mind. glad to see you found the issue. yes the screws would be removed for a rebuild so i would be talking to the shop about footing the bill for a new p/p and then you install it. worth a try your pics pretty much tell the tale
erp? last clutch you will ever buy and engagement is awesome. love mine. would still go after a new p/p from the shop. you can then post it for sale with the other parts recoup some of your money and know it is sold with no issues
Yes thats correct, cant wait to get it i have heard great things about it. Do you know if just a spec stage 3+ pressure plate can be purchased on its own? It looks like a standard oem sach pressure plate, it had a spec sticker on it, but when i removed it it showed sach. I had a custom made flywheel made for me also so can at least get something back on that.
It is way out of balance now, I would strongly suggest replacing.
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:45 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
The pressure plate is a little scarred, but no damage at all
