Spark Plugs and Coil Packs
Old Sep 15, 2015 | 12:52 PM
Highlander's Avatar
Highlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond repute
Originally Posted by jungt
The following procedure may help with the pictures.
Replacing plugs996TT
Tools
#25, 27, 40 torx socket drivers, 10mm, 13mm sockets, 5/8 spark plug socket, 5or 6mm hex socket
3/8" ratchet and 12" and 6" extension, u-joint
medium phillips screwdriver
torque wrench
-SNIP-
I have a 2002 Coupe and I used this exact procedure with a couple of differences.
Steps #10 and #11 were unnecessary. The center heatshield was not in my way, and it is easy to work around the waste gate vac hose.
Old Sep 16, 2015 | 05:28 AM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
I followed the same procedure list and agree on both points. Not sure why they tell you to pull the center heat shield.
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
jaehoppa
Oct 22, 2015 09:17 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
vogz
Sep 19, 2015 01:02 PM
