Mafless vs hitachi, vs oem maf
Actually, once you change the fuel rails out for the SRM units for example with fuel lines, etc, it will make the next fuel injector upgrade WAY easier. The only reason I am not running the 1400's is because I had a defect with them and had the FIC1100's sitting on the shelf as well...so I just threw those suckers in for now. For 600whp on e85, the 1100's should be fine. 650-700 rwhp and you might start to max them out according to the fuel calculations I've done/seen. Not worth risking it though I guess but still it's an easy switch once you go with the aftermarket fuel system.
Well if you run stock fuel pressure 1000cc injector is more than 1000cc. They are rated at 3 bars, our systems are 3.8 correct? It's twice the cost for 1300+cc as 1000cc. If I run a 5 bar fpr on stock rails with 1000cc and a 450 pump, basically I can max out the flow of the pump, injectors, and stock rails and do it for pretty cheap. Then down the road when building the motor jump up to a 1600 or 2000cc with dual pumps and rails. Spend real money on the fuel system at that point.
exactly. you are not underestimating the ability of just the 5bar to do what it should at that level though i'd guess that 1000 is pushing it and beyond that you've reached the inherent limitation of a 5bar if not in fact a single pump.
when when they work for over the 3.8 ( and up to a point..) they work just fine.
Car will run pump 90% of the time. E85 will be run on track days and occasionally on the street
I don't think I'm doing anything crazy here, am I wrong?
Like said I'd done lots of e85 stuff in the past. We have kinda crappy 91 octane here but we have awesome e85 (many station close to e90 in the summer).
I know on a V6 build on my 3 liter 6g72 (3000gt vr4), a single walbo 450, 1200cc injectors running 3bar, is enough for 750whp. That would be similar injectors flow as 1000cc at 3.8bar, just a little harder on the pump.
Whoever says they are using the stock maf with anything but stock turbo doesn't realize that the sensor get fully maxed out very quickly. You can have it in there and the car will drive fine at idle and cruise and even WOT can be fine as fueling is closed loop. But to say the stock maf is 'fine' is a huge mistake as it maxes out early and ECU goes blind to actual airflow.
Are you agreeing with me or disagreeing lol, I can't tell.
agreeing with you that where you currently are and what you're running, the 5bar should be sufficient. but i have no familiarity with corn etc. only CA craptane. but on 91-93 i dont think ( from my limited knowledge ) you are maxing out the fuel you are supplying, though a 5 bar is essentially tricking the system. it still is highly effective.. until its NOT,..and 550/575 rwhp is about "it".
proTUNING Freaks
Sep 15, 2015 07:28 AM
